We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Using advanced technology, TL-PA7017 KIT ensures stable and high-speed wired connection, providing faster data transmissions. Stream in HD, game online and download large files without interruption.
Product Description | TP-Link TL-PA7017 KIT - Starter Kit - bridge - wall-pluggable | Device Type | Bridge | Packaged Quantity | 2 (specifications are for single item) | Enclosure Type | Wall-pluggable | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV), HomePlug AV (HPAV) 2.0 | Data Transfer Rate | 1 Gbps | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, HomePlug AV, HomePlug AV 2.0 | Dimensions (WxDxH) | 6.5 cm x 5.2 cm x 2.85 cm | System Requirements | Apple MacOS, Linux, Microsoft Windows Server 2003, Microsoft Windows 2000/XP/Vista/7, Windows 8, Windows 8.1 |
General | |
Connectivity Technology | Wired |
Encryption Algorithm | 128-bit AES |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, HomePlug AV, HomePlug AV 2.0, RoHS |
Status Indicators | Power, LAN |
Line Properties | |
Line Coding Format | OFDM |
Expansion / Connectivity | |
Interfaces | LAN: 1 x HomePlug AV 2.0 , LAN: RJ-45 |
Power | |
Power Device | Internal power supply |
Miscellaneous | |
Cables Included | 1 x network cable - 2 m |
Software / System Requirements | |
OS Required | Apple MacOS, Linux, Microsoft Windows Server 2003, Microsoft Windows 2000/XP/Vista/7, Windows 8, Windows 8.1 |
Dimensions & Weight | |
Width | 6.5 cm |
Depth | 5.2 cm |
Height | 2.85 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
