With advanced HomePlug AV2 MIMO, the TL-PA9020p delivers high speed of up to 2000Mbps over powerline to provide superior network performance that supports all of your online needs. With a lag-free connection, you will never miss out again.
The TL-PA9020P creates fast, high performance wired connections that support all of your favorite devices, like 4K HDTV. Now you can plug in to enjoy an exclusive fast lane out of a crowded network without slowing down.
Product Description | TP-Link Powerline TL-PA9020P KIT - Starter Kit - powerline adapter kit - wall-pluggable | Device Type | Powerline adapter kit | Packaged Quantity | 2 (specifications are for single item) | Enclosure Type | Wall-pluggable | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV), HomePlug AV (HPAV) 2.0, IEEE 1901 | Data Transfer Rate | 2000 Mbps | Features | Quality of Service (QoS) | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3ab | Dimensions (WxDxH) | 7.2 cm x 4.2 cm x 13.1 cm | System Requirements | Apple MacOS, Linux, Microsoft Windows 2000, Microsoft Windows 2003, Microsoft Windows Vista / XP / 7 / 8 | Localisation | Australia |
General | |
Connectivity Technology | Wired |
Encryption Algorithm | 128-bit AES |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, Plug and Play, RoHS |
Status Indicators | Power, LAN |
Line Properties | |
Line Coding Format | OFDM |
Expansion / Connectivity | |
Interfaces | LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x HomePlug AV 2.0 |
Power | |
Power Device | Internal power supply |
Power Consumption Operational | 5.8 Watt |
Miscellaneous | |
Cables Included | 2 x network cable - 2 m |
Software / System Requirements | |
OS Required | Apple MacOS, Linux, Microsoft Windows 2000, Microsoft Windows 2003, Microsoft Windows Vista / XP / 7 / 8 |
Dimensions & Weight | |
Width | 7.2 cm |
Depth | 4.2 cm |
Height | 13.1 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
