TP LINK AV600 2-port Passthrough Powerline Starter Kit
£43.89
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Data transmission rates up to 600Mbps over household electrical circuit, ideal for HD video streaming
  • Integrated power socket ensures that no power outlet goes to waste
  • Plug and play design and easy encryption at a push of the pair button
  • Power-Saving Mode automatically reduces power consumption by up to 85%
  • Type: Bridge
  • Speed: 600Mbps
  • Connectivity: Wired
  • Stock Status: In Stock
Product codes
The TL-PA4020PKIT turns your home’s existing electrical circuitry into a high speed network with no need for new wires or drilling. No configuration is required, simply plug your adapter into a power socket and you can establish networking infrastructure in a flash. In addition, its integrated power socket makes sure that no power outlet is going to waste. With speeds up to 600Mbps and 300 meters over the household electric wiring, the TL-PA4020PKIT is a great choice for an easy to build multimedia entertainment network.
Product Description TP-Link TL-PA4020PKIT AV600 2-Port Powerline Adapter with AC Pass Through - V1.20 - Starter Kit - bridge - wall-pluggable
Device Type Bridge
Packaged Quantity 2 (specifications are for single item)
Enclosure Type Wall-pluggable
Data Link Protocol Ethernet, Fast Ethernet, HomePlug AV (HPAV)
Data Transfer Rate 600 Mbps
Features Integrated power socket
Compliant Standards IEEE 802.3, IEEE 802.3u, HomePlug AV
Dimensions (WxDxH) 5.8 cm x 4.2 cm x 9.5 cm
System Requirements Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK AV600 2-port P...
£43.89
