P-LINK's TL-WPA4220KIT extends your Internet connection to every room of the house through your home's existing electrical circuitry. The TL-WPA4220 features a Wi-Fi clone button enabling super range extension, which means it can automatically copy the SSID and password of your router. In this way, TL-WPA4220 simplifies your Wi-Fi configuration and allows for seamless roaming within your home network.
Product Description | TP-Link TL-WPA4220KIT AV500 WiFi Powerline Extender - V1.2 - Starter Kit - bridge - 802.11b/g/n - wall-pluggable | Device Type | Bridge | Enclosure Type | Wall-pluggable | Data Link Protocol | Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV) | Data Transfer Rate | 500 Mbps | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n | Dimensions (WxDxH) | 9.4 cm x 5.4 cm x 4 cm | System Requirements | Apple MacOS, Linux, Microsoft Windows 2000, Microsoft Windows 2003, Microsoft Windows Vista / XP / 7 / 8 |
General | |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | WPA, WPA2, WPA-PSK, 128-bit AES, WPA2-PSK, WEP |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, FCC, RoHS |
Status Indicators | Power, WLAN, LAN, link/activity |
Line Properties | |
Line Coding Format | OFDM |
Expansion / Connectivity | |
Interfaces | LAN: 2 x 10Base-T/100Base-TX - RJ-45 , 1 x HomePlug AV |
Power | |
Power Device | Internal power supply |
Power Consumption Operational | 6 Watt |
Miscellaneous | |
Included Accessories | TP-Link AV500 Nano Powerline Adapter (TL-PA4010) |
Cables Included | 1 x network cable - 2 m |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Apple MacOS, Linux, Microsoft Windows 2000, Microsoft Windows 2003, Microsoft Windows Vista / XP / 7 / 8 |
Dimensions & Weight | |
Width | 9.4 cm |
Depth | 5.4 cm |
Height | 4 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
