TP LINK AV600 Passthrough Powerline Kit
£47.38
30 in stock
Delivery:
Standard: 1-3 working days
Key features
  • High data transmission rates over household electrical circuits, ideal for HD video streaming
  • Ethernet ports allow connection of wired internet devices such as desktop computers
  • Integrated power sockets ensure no power outlet goes to waste
  • Plug-and-play design and easy encryption
  • Power-Saving mode automatically reduces power consumption
  • Type: Powerline adapter kit
  • Speed: 600Mbps
  • Connectivity: Wired
  • Stock Status: In Stock
Product codes
You need to connect your router in the living room with your desktop in the bedroom upstairs. Trailing a long Ethernet cable through the house isn't a good look, and it's expensive to install additional wiring in the walls. With powerline, there's a better way.
The TL-PA4022P KIT transforms your home's existing electrical circuit into a high speed network. No configuration is required - plug your adapter into a power socket and establish a connection within minutes.
Product Description TP-Link TL-PA4022P KIT AV600 2-port Passthrough Powerline - Starter Kit - powerline adapter kit - wall-pluggable
Device Type Powerline adapter kit
Enclosure Type Wall-pluggable
Data Link Protocol Ethernet, Fast Ethernet, HomePlug AV (HPAV)
Data Transfer Rate 600 Mbps
Features Integrated power socket
Compliant Standards IEEE 802.3, IEEE 802.3u, HomePlug AV, IEEE 1901
Dimensions (WxDxH) 5.8 cm x 4.2 cm x 9.5 cm
System Requirements Linux, Apple MacOS X 10.7 or later, Microsoft Windows Vista / XP / 7 / 8 / 8.1, Windows 10
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£47.38
