TP LINK CP220 24W 2-Port USB Car Charger - 1.65X Fast Charging
FREE DELIVERY
Key features
  • Exclusive auto detect & smart charging technology
  • 1.65x fast charging
  • Intelligent circuit design
  • Universal compatibility
  • Considerate design
Product codes
  • Exclusive Auto Detect & Smart Charging Technology
  • 1.65X Fast Charging
  • Intelligent Circuit Design
  • Universal Compatibility
  • Considerate Design
Speed
CP220 is equipped with TP-LINK Smart Charging technology and incorporates high performance dual 2.4A USB outputs. TP-LINK Smart Charging technology intelligently identifies the connected devices and the 2.4A USB ports in CP220 allow you to charge devices with large battery like tablets, or gadgets with tiny battery like smart wearable devices at full speed on the road.
30 mins drive adds 9 additional using hours
As measured by the charging capacity in 30 mins on iPhone 6s Plus, it charges up to 38% within the drive in order to provide 9 additional hours 3G talk time for further use.
1.65X Fast Charging compared with original charger
Charge 65% faster, save up to 40% charging time. Fully charging iPhone 6s Plus takes 150 mins with CP220 while it takes 250 mins with an original Apple charger.
Compatible with smart devices running iOS, Android, Windows and most other USB-charged devices, such as Satellite Navigation and Dashcams. CP220 fully supports and is applicable to most of the current car models.
A unique crown design
The crown design ensures users insert CP220 in the right position and connect devices in the most convenient way.
Built in soft internal LED power indicator
A dimmed LED indicator helps visualize the connection status and does not distract you while driving.
TP-Link CP220 - car power adapter
Car power adapter
2.7 cm x 2.8 cm x 7.7 cm
Output Connector Type
USB
12 - 24 V
Voltage Provided
5 V
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK CP220 24W 2-Po...
