With 23dBi high-gain directional Cassegrain antenna and dedicated metal reflector, the CPE605 provides excellent beam directivity, improved latency and noise immunity. Professional performance, coupled with user-friendly design, makes the 5GHz 150Mbps 23dBi Outdoor CPE605 an ideal choice and cost-effective solution for outdoor wireless networking applications.
Product Description | TP-Link CPE605 - radio access point - Wi-Fi | Device Type | Radio access point | Form Factor | External - outdoor | Processor | 1 x Qualcomm MIPS 74KC 560 MHz | RAM | 64 MB | Flash Memory | 8 MB | Data Link Protocol | IEEE 802.11a, IEEE 802.11n | Frequency Band | 5 GHz | Included Accessories | PoE injector, pole mount | OS Required | UNIX, Apple MacOS, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows NT, Microsoft Windows 2000/XP/Vista/7/8/10 | Power Over Ethernet (PoE) Supported | PoE | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 35 cm x 25.5 cm x 20.7 cm |
General | |
Ruggedized Design | Outdoor |
Width | 35 cm |
Depth | 25.5 cm |
Height | 20.7 cm |
Processor / Memory / Storage | |
Processors Installed | 1 x Qualcomm MIPS 74KC 560 MHz |
Max Supported Qty | 1 |
RAM | 64 MB DDR2 SDRAM |
Networking | |
Form Factor | External |
Connectivity Technology | Wireless |
Data Transfer Rate | 150 Mbps |
Network / Transport Protocol | PPTP, L2TP, PPPoE, DHCP, DDNS |
Routing Protocol | Static IP routing |
Remote Management Protocol | SNMP 2c, HTTP, HTTPS, SSH, DHCP |
Features | Firewall protection, DHCP support, power over Ethernet (PoE), Syslog support, ALG support, MAC address filtering, Wireless Distribution System (WDS) support, Access Point operational mode, 15 KV Electrostatic Discharge Protection, virtual server support, Multiple SSID support, reset button, bandwidth control, port triggering, weatherproof, Stateful Packet Inspection Firewall (SPIF), IP-MAC binding, static routing, SNMP support, Time Division Multiple Access (TDMA), Dynamic Frequency Selection (DFS), SSID to VLAN tagging, Denial of Service (DoS) protection, dustproof, waterproof, L2TP support, 6KV lightning protection |
Encryption Algorithm | AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK |
Authentication Method | Secure Shell (SSH) |
Compliant Standards | IEEE 802.11a, IEEE 802.11n, UPnP |
Aerial | |
Antenna | Internal |
Antenna Qty | 1 |
Directivity | Directional |
Gain Level | 23 dBi |
Expansion / Connectivity | |
Interfaces | 1 x 100Base-TX (PoE) - RJ-45 |
Miscellaneous | |
Compliant Standards | FCC, RoHS, IP65 |
Power | |
Power Device | Power injector |
Voltage Required | AC 120/230 V (50/60 Hz) |
Software / System Requirements | |
Environmental Parameters | |
Min Operating Temperature | -40 °C |
Max Operating Temperature | 70 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
