TP LINK Deco P9 AC1200+AV1000 Powerline built-in 3-pack
£144.99
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00
    h
  • 00
    m
  • 00
    s
Key features
  • Wi-Fi + PLC Hybrid Mesh: Hybrid network boosts bandwidth effectively
  • With powerline, there is no more walls or distance limits, enjoy home Wi-Fi everywhere
  • Supports connection to 100+ devices
  • Type: Wi-Fi system
  • Connectivity: Wired, Wireless
  • Speed: 1167Mbps
  • Protocol: Ethernet, IEEE 802.11ac, IEEE 802.11b, Gigabit Ethernet + 5 more
Product codes
Deco P9 combines dual-band Wi-Fi and powerline to establish a stronger mesh network. Powerline technology uses your home's electrical wiring to create stronger connections between Deco units, reducing the impact of walls and other obstacles on signal and providing even faster network speeds and truly seamless coverage.
The hybrid whole-home system delivers extended coverage up to 6,000 ft2/560 m2 with the help of the combination of dual-band Wi-Fi and powerline. Eliminate weak signal areas with whole-home Wi-Fi and no more searching around for a stable connection.
TP-Link Mesh means Deco units work together to form one unified network. Your phone or tablet automatically connects to the fastest Deco as you move through your home, creating a truly seamless Wi-Fi experience.
Dual-Band Wi-Fi + Powerline - AC1200 dual-band Wi-Fi + AV1000 powerline combines for speeds of up to 2200 Mbps
Signal Works through Walls - Transmit data using your home’s electrical wiring, no worries about Wi-Fi dragging down by walls or ceilings.
Connect More Devices - Deco handles traffic from even the busiest network, providing lag-free connections up to 100 devices.
Seamless Roaming - Deco units work together to form a unified network. Walk through your home and stay connected with the fastest possible speeds.
MU-MIMO Technology - Simultaneously transfers data to multiple devices for faster performance.
Quality of Service - Prioritize devices for faster performance when needed.
Robust Parental Controls - Manage content and control when each device can access the internet.
Setup Made Easier than Ever - The Deco app walks you through setup step by step.
Great Compatibility - All Decos work together.
Product Description TP-Link Deco P9 - Wi-Fi system - 802.11a/b/g/n/ac, Bluetooth 4.2 - desktop
Device Type Wi-Fi system
Enclosure Type Desktop
Wi-Fi System Components 3 routers
Wi-Fi System Coverage Up to 6,000 sq.ft
WAN Ports Qty 2
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
Frequency Band 2.4 GHz / 5 GHz
Data Transfer Rate 1167 Mbps
Network / Transport Protocol PPPoE, DHCP, DDNS
Routing Protocol Static IP routing
Features IPv6 support, parental control, Access Point operational mode, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), DHCP server, port forwarding, reset button, IPv4 support, Stateful Packet Inspection Firewall (SPIF), dynamic IP mode, DHCP client, anti-virus protection, router mode, TP-Link Adaptive Routing Technology
Compliant Standards IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Dimensions (WxDxH) 9.07 cm x 9.07 cm x 19 cm
System Requirements Android 4.3 or later, Apple iOS 8.0 or higher
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£144.99
