TP LINK EAP110 300Mbps Wireless N Ceiling Mount Access Point
£29.54
Delivery:
Standard: 1-3 working days
Key features
  • Supports passive PoE for convenient installation
  • Ceiling mounting design with chassis make it easy to deploy on a wall or ceiling
  • Captive portal provides one convenient method of authentication for Wi-Fi guests
  • Multi-SSID divides multiple wireless networks for different users
  • Enterprise class Wi-Fi security help to decrease network security threats
  • Type: Radio access point
  • Connectivity: Wireless
  • Speed: 300Mbps
  • Protocol: Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g + 1 more
  • Compatibility: PC
Product codes
The TP-LINK's EAP110 business Access Point provides a flexible, easy-to-deploy, manageable and robust security business-class wireless network solution. Simple mounting design to easily mount to a wall or ceiling. WLAN configuration and management are simplified through centralized management software. EAP110 also features captive portal and auto RF management, making it ideal for the high-density, intensive demanding businesses environment, include campus, hotels, malls and offices.
Flexible Placement - Easy mounting design & PoE
The EAP110's "ceiling lamp" appearance and easy mounting design with chassis make it easy to be integrated seamlessly into any wall or ceiling surface to blend in with most interior decorations. EAP110 supports Passive Power over Ethernet (Passive PoE) to make deployment effortless and flexible. Simple and Scalable Business Wi-Fi Management - EAP Controller Software
The EAP Controller Software represents a cost-effective 'centralized management' solution for wireless networks of both small and medium business sectors (SMB). The software enables administrators to manage hundreds of EAPs easily from any PC on the network. Includes such administrative features as centralized configuration, real-time monitoring, graphical analysis of network traffic and batch firmware updates.
Powerful and Intuitive Software
Free controller software, no additional hardware controller required
Easy-to-use, no special training necessary
Upload floor plans for a more Intuitive Wi-Fi management
Batch firmware update support for effective administration
Advanced security features including Captive Portal, Rogue AP Detection
Visual Network Monitoring
Intuitively view traffic on any individual AP on the network
Graphical activity of clients connected to the network
Visual analytics of overall network usage and traffic distribution
Efficient Guest Authentication - Captive Portal
Captive portal provides one convenient method of authentication for Wi-Fi guests. A captive portal requires users to perform certain actions before network access is allowed. The required action must be verified by an external portal server or customized database by the administrator, which can be simply viewing and agreeing to an acceptable use policy, or entering a user ID and password.
Robust Safety Strategy - Multiple Wi-Fi Security Measures
The EAP110 supports the enterprise class Wi-Fi security, including WPA/WPA2-enterprise encryption and 802.1X radius. In addition, Multi-SSID, Wireless Isolation, MAC Filtering and Rogue AP detection features help to decrease network security threats.
Applicable to Multi-user Environment - Designed for Enterprise Performance
With easy mounting design, PoE power supply, Centralized management software, Captive portal, enterprise class security, and Enterprise hardware, EAP110 is specially designed for the highest-density, most demanding enterprise environments, including schools, hotels, and enterprises.
Product Description TP-Link Omada EAP110 - radio access point
Device Type Radio access point
Form Factor External
Data Link Protocol Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band 2.4 GHz
Capacity Maximum number of configured SSIDs: 8
Included Accessories PoE injector, wall mounting kit
OS Required Microsoft Windows Vista / XP / 7 / 8
Power Over Ethernet (PoE) Supported PoE
Dimensions (WxDxH) 18.94 cm x 17.23 cm x 2.95 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK EAP110 300Mbps...
£29.54
