TP LINK EAP225-Outdoor - Radio access point - Wi-Fi - Dual B
£82.90
Delivery:
Standard: 1-3 working days
Key features
  • Durable, weatherproof enclosure for outdoor Wi-Fi applications
  • Up to 1200 Mbps with 2x2 MIMO technology
  • High transmission power and high gain antennas provide a long-range coverage area
  • Captive portal provides a convenient method for guest authentication
  • Facebook Wi-Fi and SMS authentication help to boost your business
  • 802.3af/Passive PoE compatible and simple mounting design allow for flexible deployment and convenient installation
  • Type: Radio access point
  • Connectivity: Wireless
  • Speed: 867Mbps
  • Protocol: IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g + 1 more
  • Stock Status: In Stock
Product codes
802.11k and 802.11v seamless roaming provide seamless switching to the access point with optimal signal when moving between APs. Omada Mesh technology enables wireless connectivity between access points for extended range, making wireless deployments more flexible and convenient.
Product Description TP-Link EAP225-Outdoor - radio access point
Device Type Radio access point
Form Factor External - outdoor
Data Link Protocol IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band 2.4 GHz, 5 GHz
Capacity Maximum number of configured SSIDs: 16
Included Accessories PoE injector, pole mount, wall mounting kit
Power Over Ethernet (PoE) Supported PoE
Dimensions (WxDxH) 4.6 cm x 2.7 cm x 21.5 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK EAP225-Outdoor...
£82.90
