We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Marketing description is not available.
Product Description | TP-Link TL-SG105PE - switch - 5 ports - Managed | Device Type | Switch - 5 ports - Managed | Subtype | Gigabit Ethernet | Ports | 5 x 10/100/1000 (4 PoE+) | Power Over Ethernet (PoE) | PoE+ | PoE Budget | 65 W | Performance | Switching capacity: 10 Gbps , Packet forwarding rate: 7.44 Mpps | Capacity | Packet buffer size: 1.5 MB , Priority queues: 4 , Virtual interfaces (VLANs): 32 | MAC Address Table Size | 2K entries | Jumbo Frame Support | 16KB | Routing Protocol | IGMPv2, IGMP, IGMPv3 | Features | Auto-negotiation, auto-uplink (auto MDI/MDI-X), port mirroring, store and forward, Cable Diagnostics Function, fanless, loop prevention, tagged VLAN, DiffServ Code Point (DSCP) support, Storm Control, rate limit, Static Link Aggregation, extend mode | Compliant Standards | IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at |
General | |
Enclosure Type | Desktop |
PoE Budget | 65 W |
Status Indicators | Status |
Expansion / Connectivity | |
Interfaces | 5 x 1000Base-T RJ-45 4 ports (PoE+) - 30 W |
Power | |
Power Device | External power adapter |
Power Provided | DC 53.5 V - 1.31 A |
Power Consumption Operational | 75.16 Watt |
Miscellaneous | |
Included Accessories | Rubber feet |
Compliant Standards | FCC, RoHS |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 5 - 95% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
