TP LINK HS100 Kit Kasa Smart Wifi Plug 2-Pack
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Remote access
  • Scheduling
  • Energy monitoring
  • Away mode
  • Type: Smart plug
  • Compatible With: Alexa, Google Assistant, SmartThings
  • Stock Status: In Stock,
    Used stock also available below
Product codes
Bundle deals (2)
GET VOICE CONTROL WITH ALEXA
= £74.98
Save £15.00
GET VOICE CONTROL WITH GOOGLE ASSISTANT
= £83.99
Smart Control for A Smart Home
Manage Your Home Electronics and Appliances Anytime, Anywhere
The smart plug is easy to set up, and make it even easier to manage your household electronic devices anywhere in the world with a tap of your smartphone.
You’re Always Home
Add an extra layer of security with Away Mode. Connected devices will randomly turn on and off throughout the day to make it look like you’re home.
Modern, Elegant, Simple
Inspired by a modern sensibility, the smart plug's design is both simple and elegant, allowing it to blend seamlessly with existing decor.
Never Leave Things Running
The smart plug gives you a peace of mind with the count down timer feature, which automatically switches off the running household appliances (clothes iron and curling iron) if you have set a time limit before.
Your Voice Has Power
Control your device with simple voice commands and an Amazon Alexa, Google Assistant, or Microsoft Cortana.
Product Description TP-Link HS100 - smart plug
Product Type Smart plug
Packaged Quantity 2 (specifications are for single item)
Connectivity Wireless - 802.11b/g/n
Frequency Band 2.4 Ghz
Supported Host Device OS iOS, Android
Localisation United Kingdom
Dimensions (WxDxH) 10.03 cm x 6.63 cm x 4.68 cm
Warranty 2 year warranty
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: F0W6 042468
£30.66
product
Ref: F0W6 042468
Accessories
Packaging
Functional
Software
Manuals
£30.66
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK HS100 Kit Kasa...
£39.99
