TP LINK HS100 Wi-Fi Smart Plug
FREE DELIVERY
£29.00
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Remote access
  • Scheduling
  • Energy monitoring
  • Away mode
Product codes
Smart Control for A Smart Home
Remote Access – Control devices connected to the Smart Plug wherever you have Internet using the free Kasa app on your smartphone.
Scheduling – Schedule the Smart Plug to automatically power electronics on and off as needed, like setting lights to come on at dusk or turn off at sunrise.
Away Mode – Turns your devices on and off at different times to give the appearance that someone is home.
Voice Control – Pair to Amazon Alexa or The Google Assistant to enable voice control.
Easily Manage Your Home Electronics and Appliances Anytime, Anywhere
The Smart Plugs are easy to set up, and make it even easier to manage your household electronic devices anywhere in the world with a tap of your smartphone.
You’re Always Home
Deter bad guys by setting your lights to turn on and off on a schedule so it seems like you’re home when you are actually away.
Control and Automate without Getting Out of Bed
With a tap on your smartphone, you can easily turn off the lights and other devices in the living room without getting out of bed, or conveniently schedule all lights to go off by midnight.
Modern, Elegant, Simple
Inspired by a modern sensibility, the Smart Plug’s design is both simple and elegant, allowing it to blend seamlessly with existing decor.
Never Leave Things Running
The Smart Plugs give you a peace of mind with the count down timer feature, which automatically switches off the running household appliances (clothes iron and curling iron) if you have set a time limit before.
Compatible with Android, iOS and Amazon Echo
You can pair the Smart Plugs with Amazon Echo for voice control. And the free Kasa app lets you run them from any Android ( 4.1 and higher ) or iOS ( iOS 8 and higher ) smartphone.
IFTTT
IFTTT is a free platform that helps you do more with all your apps and devices. Kasa by TP-Link is a leading smart home system that includes Kasa Smart Plugs, Smart Bulbs, Smart Switches and more. It works with other leading smart home products such as Amazon Echo, Google Home, and more. Now with IFTTT, you can also create personalized Applets that trigger automatic actions on your Kasa devices.
Our favourite TPLink Kasa Applet: Turn on your lights at sunset
Turn on your light within 15 minutes of the sunset at your location - by TP-Link Kasa - https://ifttt.com/applets/fjksUhKu-turn-on-your-light-at-sunset
See all TPLink Applets on IFTTT here: https://ifttt.com/kasa
TP-Link HS100 - smart plug
Smart plug
Wireless - 802.11b/g/n
Supported Host Device OS
iOS, Android
6.63 cm x 7.7 cm x 10.03 cm
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK HS100 Wi-Fi Sm...
£29.00
