TP LINK HS110 V2.1 Smart Plug with Energy Monitoring
£34.99
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Remote access
  • Scheduling
  • Energy monitoring
  • Away mode
Product codes
Kasa Smart Wi-Fi Plug v2.1 with Energy Monitoring
Remote Access – Easy setup and control from anywhere with the free Kasa app (iOS, Android).
Scheduling – Schedule the Smart Plug to automatically power electronics on and off as needed, like setting lights to come on at dusk or turn off at sunrise.
Energy Monitoring – Analyze a device’s real-time and historical power consumption.
Away Mode – Turns your devices on and off at different times to give the appearance that someone is home.
Voice Control – Pair to Amazon Alexa or The Google Assistant to enable voice control
Easily Manage Your Home Electronics and Appliances Anytime, Anywhere
The Smart Plugs are easy to set up, and make it even easier to manage your household electronic devices anywhere in the world with a tap of your smartphone.
You’re Always Home
Deter bad guys by setting your lights to turn on and off on a schedule so it seems like you’re home when you are actually away.
Control and Automate without Getting Out of Bed
With a tap on your smartphone, you can easily turn off the lights and other devices in the living room without getting out of bed, or conveniently schedule all lights to go off by midnight.
Save Money When You Warm Up and Cool Off
You can efficiently conserve energy and save money while using the Smart Plugs to control your kettles and fans. The Smart Plug tracks your device’s power consumption in real-time, and has weekly and monthly summaries.
Customer reviews
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: F1ZM 040048
£28.22
product
Ref: F1ZM 040048
Accessories
Packaging
Functional
Software
Manuals
£28.22
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK HS110 V2.1 Sma...
£34.99
