TP LINK HS110 V2.1 Smart Plug with Energy Monitoring
More than 50 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Remote access
  • Scheduling
  • Energy monitoring
  • Away mode
  • Type: Smart plug
  • Compatible With: Alexa, Google Assistant, Nest
  • Stock Status: In Stock
Product codes
Bundle deals (4)
KASA STARTER KIT - BULBS AND SMART PLUGS
= £74.98
Save £30.00
GOOGLE NEST HUB MAX
GOOGLE NEST HUB MAX
= £173.99
Save £20.00
KASA SMART POWER STRIP
= £49.97
Save £5.00
NEST MINI
NEST MINI
= £44.99
Save £3.99
Kasa Smart Wi-Fi Plug v2.1 with Energy Monitoring
Remote Access – Easy setup and control from anywhere with the free Kasa app (iOS, Android).
Scheduling – Schedule the Smart Plug to automatically power electronics on and off as needed, like setting lights to come on at dusk or turn off at sunrise.
Energy Monitoring – Analyze a device’s real-time and historical power consumption.
Away Mode – Turns your devices on and off at different times to give the appearance that someone is home.
Voice Control – Pair to Amazon Alexa or The Google Assistant to enable voice control
Easily Manage Your Home Electronics and Appliances Anytime, Anywhere
The Smart Plugs are easy to set up, and make it even easier to manage your household electronic devices anywhere in the world with a tap of your smartphone.
You’re Always Home
Deter bad guys by setting your lights to turn on and off on a schedule so it seems like you’re home when you are actually away.
Control and Automate without Getting Out of Bed
With a tap on your smartphone, you can easily turn off the lights and other devices in the living room without getting out of bed, or conveniently schedule all lights to go off by midnight.
Save Money When You Warm Up and Cool Off
You can efficiently conserve energy and save money while using the Smart Plugs to control your kettles and fans. The Smart Plug tracks your device’s power consumption in real-time, and has weekly and monthly summaries.
Product Description TP-Link HS110 - V2.1 - smart plug
Product Type Smart plug
Functions Energy use monitor, turn power on/off
Connectivity Wireless - 802.11b/g/n
Frequency Band 2.4 Ghz
Supported Host Device OS iOS, Android
Dimensions (WxDxH) 6.63 cm x 7.7 cm x 10.03 cm
Warranty 2 year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK HS110 V2.1 Sma...
£24.99
