TP LINK JetS 8P GB Smart PoE Switch-2 SFP Slots
£97.29
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Advanced QoS features
  • Abundant layer 2 features
  • Management features
  • Type: Gigabit Ethernet
  • Ports: 8
  • Managed: Yes
  • POE: PoE
  • Stock Status: In Stock
Product codes
TP-LINK T1500G-10PS switch is equipped with useful PoE power management features. The switch provides high performance, enterprise-level QoS, useful security strategies and rich layer 2 management features.
Product Description TP-Link JetStream T1500G-10PS - switch - 8 ports - Managed
Device Type Switch - 8 ports - Managed
Subtype Gigabit Ethernet
Ports 8 x 10/100/1000 (PoE) + 2 x SFP
Power Over Ethernet (PoE) PoE
PoE Budget 53 W
Performance Switching capacity: 20 Gbps , Forwarding performance: 14.9 Mpps
Capacity VLAN IDs: 4000 , Simultaneous VLANs: 512
MAC Address Table Size 8K entries
Jumbo Frame Support 9KB
Remote Management Protocol SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, TFTP, SSH, SSH-2, CLI
Features Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, fanless, LACP support, LLDP support, Class of Service (CoS), DiffServ Code Point (DSCP) support, Storm Control, LLDP-MED
Compliant Standards IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP)
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 20.9 cm x 12.6 cm x 2.6 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK JetS 8P GB Sma...
£97.29
