We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The T1500-28PCT provides 24 10/100Mbps ports that supports 802.3at/af-compliant PoE, with a total PoE power supply up to 180W, powerful and flexible enough for users to deploy wireless access points or IP-based network surveillance cameras. The switch also comes equipped with 4 10/100/1000Mbps RJ45 ports and 2 combo SFP slots, expanding your network flexibly. In addition, it provides high performance, enterprise-level QoS, useful security strategies and rich layer 2 management features.
TP-LINK Smart PoE Switch T1500-28PCT is a cost-effective product solution for the small and medium business. T1500-28PCT has useful security features. The Storm Control feature protects against Broadcast, Multicast and Unknown unicast Storm. Quality of Service (QoS, L2 to L4) provides enhanced traffic management capabilities to move your data smoother and faster. Anymore, the easy-to-use web management interfaces, along with SNMP and RMON, mean faster setup and configuration with less downtime. For workgroup and departments requiring cost-sensitive layer 2 switch, TP-LINK smart PoE switch T1500-28PCT provides you the ideal access-edge solution.
Product Description | TP-Link Smart PoE Switch T1500-28PCT - switch - 24 ports - rack-mountable | Device Type | Switch - 24 ports | Enclosure Type | Rack-mountable 1U | Subtype | Fast Ethernet | Ports | 24 x 10/100 (PoE) + 2 x SFP + 4 x 10/100/1000 | Power Over Ethernet (PoE) | PoE | Performance | Bandwidth: 12.8 Gbps , Forwarding performance: 9.5 Mpps | Capacity | Active VLANs: 512 | MAC Address Table Size | 8K entries | Jumbo Frame Support | 9KB | Routing Protocol | IGMPv2, IGMP, IGMPv3 | Remote Management Protocol | SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, SSH, SSH-2, CLI | Features | Flow control, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, manageable, store and forward, MAC address filtering, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Cable Test (VCT) technology, Multiple Spanning Tree Protocol (MSTP) support, Quality of Service (QoS), SSH support, Management Information Base (MIB), Class of Service (CoS), Loopback, DiffServ Code Point (DSCP) support, 2 fans | Compliant Standards | IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 44 cm x 22 cm x 4.4 cm | System Requirements | UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows Vista / XP, Microsoft Windows 7 / Windows 8 |
General | |
Encryption Algorithm | TLS 1.0, SSL 3.0, SSL 2.0 |
Authentication Method | Secure Shell (SSH), Secure Shell v.2 (SSH2) |
Status Indicators | Port transmission speed, power, link/activity |
Expansion / Connectivity | |
Interfaces | 24 x 100Base-TX RJ-45 PoE , 4 x 1000Base-T RJ-45 , 2 x Gigabit LAN SFP |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Miscellaneous | |
Included Accessories | Rubber feet |
Rack Mounting Kit | Included |
Compliant Standards | FCC, RoHS |
Software / System Requirements | |
OS Required | UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows Vista / XP, Microsoft Windows 7 / Windows 8 |
Dimensions & Weight | |
Width | 44 cm |
Depth | 22 cm |
Height | 4.4 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 5 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
