We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Designed for workgroups and departments, T2500G-10TS provides full set of Layer 2 management features. It delivers maximum throughput where you need it - to high-performance workgroups at the edge of the network, or as a backbone for Gigabit switches and high-speed servers.
Product Description | TP-Link JetStream T2500G-10TS - switch - 8 ports - Managed - rack-mountable | Device Type | Switch - 8 ports - Managed | Enclosure Type | Rack-mountable 1U | Subtype | Gigabit Ethernet | Ports | 8 x 10/100/1000 + 2 x Gigabit SFP | Performance | Bandwidth: 20 Gbps , Packet forwarding rate: 14.9 Mpps | MAC Address Table Size | 8K entries | Jumbo Frame Support | 9KB | Remote Management Protocol | SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, TFTP, SSH, SSH-2, CLI | Features | Flow control, Layer 2 switching, DHCP support, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DoS attack prevention, port mirroring, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Cable Test (VCT) technology, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, Dynamic ARP Inspection (DAI), fanless, Link Aggregation Control Protocol (LACP), Port Security, IP-MAC binding, SNMP trap, Generic Attribute Registration Protocol (GARP), Generic VLAN Registration Protocol (GVRP) | Compliant Standards | IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1v, IEEE 802.3av | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 29.4 cm x 18 cm x 4.4 cm |
General | |
Enclosure Type | Desktop, rack-mountable 1U |
Encryption Algorithm | TLS 1.0, SSL 3.0, SSL 2.0 |
Authentication Method | RADIUS |
Expansion / Connectivity | |
Interfaces | 8 x 1000Base-T RJ-45 , 1 x console RJ-45 , 2 x 1000Base-X SFP , 1 x console (micro-USB) |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 8.38 Watt |
Miscellaneous | |
Included Accessories | Rubber feet |
Rack Mounting Kit | Included |
Compliant Standards | FCC |
Dimensions & Weight | |
Width | 29.4 cm |
Depth | 18 cm |
Height | 4.4 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 5 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
