We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
TP-Link JetStream Gigabit L2 managed switch T2600G-18TS provides 16 10/100/1000Mbps ports and 2 Gigabit SFP Slots. The switch provides high performance, powerful L2 and L2+ features like static routing, enterprise-level QoS and other advanced security strategies. The IP-MAC-Port Binding and Access Control List (ACL) functions protect against broadcast storm, ARP and Denial-of-Service (DoS) attacks, etc. Quality of Service (QoS, L2 to L4) provides enhanced traffic management capabilities to move your data smoother and faster. Moreover, the easy-to-use web management interfaces, along with CLI, SNMP, RMON and Dual Image mean faster setup and configuration with less downtime. For workgroup and departments requiring cost-sensitive L2 Switch and gigabit capability, TP-Link JetStream 16-Port Gigabit L2 managed Switch T2600G-18TS provides you the ideal network solution.
Product Description | TP-Link JetStream T2600G-18TS - switch - 16 ports - Managed - rack-mountable | Device Type | Switch - 16 ports - Managed | Enclosure Type | Rack-mountable 1U | Subtype | Gigabit Ethernet | Ports | 16 x 10/100/1000 + 2 x combo Gigabit SFP | Performance | Switching capacity: 36 Gbps , Forwarding performance: 26.78 Mpps | MAC Address Table Size | 8K entries | Jumbo Frame Support | 9216 bytes | Routing Protocol | IGMP | Remote Management Protocol | SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, CLI | Features | Flow control, Layer 2 switching, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, IPv6 support, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, MLD snooping, Device Link Detection Protocol (DLDP) support, LACP support, DHCP relay, Dynamic VLAN Support (GVRP), loop prevention, static routing, tagged VLAN, Generic Attribute Registration Protocol (GARP), DiffServ Code Point (DSCP) support, IGMP filtering, IGMP throttling, IP source guard, ARP inspection, Bridge protocol data unit (BPDU), layer 2+ switching, rate limit, Digital Diagnostics Monitoring (DDM), IP/Mac/Port Binding (IPMB) | Compliant Standards | IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 44 cm x 22 cm x 4.4 cm | Manufacturer Warranty | Limited lifetime warranty |
General | |
Encryption Algorithm | TLS 1.0, SSL 3.0 |
Authentication Method | Secure Shell (SSH), RADIUS, Secure Shell v.2 (SSH2), internal user database |
Expansion / Connectivity | |
Interfaces | 16 x 1000Base-T RJ-45 , 2 x 1000Base-X SFP , 1 x console RJ-45 management |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 11.47 Watt |
Miscellaneous | |
Included Accessories | 4 rubber feet |
Rack Mounting Kit | Included |
Compliant Standards | FCC, RoHS |
Dimensions & Weight | |
Width | 44 cm |
Depth | 22 cm |
Height | 4.4 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 5 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
