TP Link Kasa Smart Wi-Fi LED Bulb with Multicolour
FREE DELIVERY
Key features
  • No hub required - connect the bulb directly to your Wi-Fi at home
  • Manage remotely - control your lights from anywhere with your tablet or smartphone
  • Color changing hue - fine-tune up to 16 million colors and adjust brightness as well as light appearance from soft white to daylight
  • Circadian mode - dynamically adjust light intensity and temperature to mimic natural light patterns
  • Save energy - reduce energy without brightness or quality loss
Product codes
Documents
Control your lighting from anywhere with the LB130. The smart bulb installs as easily as a standard light bulb, and connects to your home Wi-Fi in no time through the free Kasa app. Kasa lets you manage your lights with your smartphone or tablet, including adjusting brightness, setting schedules and scenes, and tracking energy used. The LB130 can also change colour, with more than 16 million hues available to match any mood or occasion. For added convenience, you can control the LB130 with your voice when paired with amazon Alexa.
The Bulb has an E27 screw fixture, with a B22 bayonet adapter included in the box.
No Hub Required
Connect the bulb directly to your Wi-Fi at home.
Control from Anywhere
Connect the LB130 to your home Wi-Fi network and control it directly from anywhere using the Kasa® app. Kasa lets you manage your lights with your smartphone or tablet, including adjusting colour and brightness, setting schedules and scenes, and tracking energy used.
Colour Changing Hue
Fine-tune up to 16 million colours and adjust brightness as well as light appearance from soft white (2700k) to daylight (9000k)
Voice Control
Your Voice Has Power. Control your device with simple voice commands and an Amazon Alexa, Google Assistant, or Microsoft Cortana.
Circadian Mode
Circadian Mode automatically matches light appearance to the time of day by adjusting brightness and warmth as the sun rises and sets. Wake up refreshed and fall asleep easily with natural lighting.
Enjoy Peace of Mind
Schedule the LB130 Smart Bulbs around your life and have them to turn on, off, and adjust their light appearance to suit your preference. They can even adjust automatically to changing sunset and sunrise times so it comes on when it gets dark and turns off as the sun comes up.
Customize and Set Scenes
Change the colour and intensity as you wish, navigate the tunable white light from warm to cool until you feel comfortable. Smart Wi-Fi bulbs can be controlled separately or as a group, and your favorite settings can be saved as scenes accessible in Kasa app.
Save Energy with LED Bulb
Reduce energy used by up to 80% without brightness or quality loss compared to a 60W incandescent bulb, and lasts up to 22.8 years.
Package Contents:
Smart Wi-Fi LED Bulb LB130
Quick Installation Guide
B22 (bayonet) adaptor
IFTTT
IFTTT is a free platform that helps you do more with all your apps and devices. Kasa by TP-Link is a leading smart home system that includes Kasa Smart Plugs, Smart Bulbs, Smart Switches and more. It works with other leading smart home products such as Amazon Echo, Google Home, and more. Now with IFTTT, you can also create personalized Applets that trigger automatic actions on your Kasa devices.
Our favourite TPLink Kasa Applet: Turn on your lights at sunset
Turn on your light within 15 minutes of the sunset at your location - by TP-Link Kasa - https://ifttt.com/applets/fjksUhKu-turn-on-your-light-at-sunset
See all TPLink Applets on IFTTT here: https://ifttt.com/kasa
Product Description TP-Link LB130 - LED light bulb
Light Source Type LED light bulb
Bulb Finish Frosted
Wattage Equivalent 60 W
Light Bulb Energy Efficiency Class A+
Colour of Illumination 16 million colours
Colour Temperature 2700-9000 K
Luminous Power 800 lumens
Dimmable Yes
Intelligent Assistant Alexa
Resources
The following resources are available for the TP Link Kasa Smart Wi-Fi LED Bulb with Multicolour
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP Link Kasa Smart Wi-...
