TP LINK KC100 Full HD WiFi Smart Camera
£39.99
20 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Motion snapshots
  • Clear video
  • Activity zones
  • Two-way talk
  • Type: Indoor Camera
  • Compatible With: Alexa, Google Assistant
  • Stock Status: In Stock
Product codes
Kasa Spot - KC100
Keep an eye on your things with Kasa Smart Spot, an HD indoor security camera.
Crystal Clear Video
Sharp and clear 1080p full-HD provides high-quality video right in the palm of your hand.
Wide Angle Field Of View
The Spot's 130°, wide-angle field of view makes sure nothing is out of view. Set it up in a corner and get a full view of your living room or place it on top of a shelf to get a great view of your kitchen.
Instant Activity Alerts
No need to check your Kasa Spot throughout the day. Get automatic alerts when your Spot detects motion or sound.
Night Vision
Even in the dark, the Kasa Spot has Night Vision up to 20 feet. Never miss a thing at night and still get the same high-quality video you’re used to.
Two-way Audio
Use crisp two-way audio to communicate with nosy roommates, family or even mischievous pets.
Activity Zones
Configure up to 4 customizable zones for more meaningful alerts at no cost to you. Place zones around your front door, kitchen or anywhere you like to focus your camera’s view.
24/7 Live View
Keep an eye on what’s important to you real-time from anywhere with the Kasa Smart app. Even stream live video to any Alexa or Google Assistant supported display, like a Fire TV, Echo Show or Chromecast.
Product Description Kasa Smart Spot - network surveillance camera
Device Type Network surveillance camera - fixed - indoor
Audio Yes: built-in speaker, two-way audio capability, built-in microphone
Dimensions (WxDxH) 5.89 cm x 4.95 cm x 8.86 cm
Weight 68 g
Connectivity Technology Wireless
Camera Colour - Day&Night
Max Resolution 1920 x 1080
Frame Rate (max) 15 frames per second
Motion Detection Yes
Video Modes 1080p
Interfaces IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Cables Included 1 - USB cable - external - 3.05 m
Voltage DC 5 V
Features Audio Detection, activity detection
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK KC100 Full HD...
£39.99
