Up, Down, All-Around
Get the full picture of any space in your apartment, dorm or home with the Kasa Spot Pan Tilt. With a 360° horizontal view and 118° vertical view, the Pan Tilt has everything covered.
CRYSTAL CLEAR VIDEO
Sharp and clear 1080p full-HD provides high-quality video right in the palm of your hand.
PAN AND TILT
The Kasa Spot Pan Tilt indoor security camera is perfect for wide-open living spaces and can rotate to cover multiple points in your room. With 360° rotational and 118° vertical views, the pan tilt camera can monitor every angle of any room.
MOTION TRACKING
When motion is detected, the Kasa Spot Pan Tilt will continue tracking the activity until it has stopped even if is out of the camera’s normal view. If your four-legged friend walks into your camera’s view, the pan tilt camera will track their motion until they’ve found a spot to settle down in.
PATROL MODE
Set four distinct viewpoints in your living space so when action occurs in one of those areas the camera will automatically rotate to capture activity. Program your Pan Tilt camera to keep an eye on each region at intervals of your choosing.
24/7 LIVE VIEW
Keep an eye on what’s important to you real-time from anywhere with the Kasa Smart app. Even stream live video to any Alexa or Google Assistant supported display, like a Fire TV, Echo Show or Chromecast.
TWO-WAY AUDIO
Use crisp two-way audio to communicate with nosy roommates, family or even mischievous pets.
NIGHT VISION
Even in the dark, the Kasa Spot Pan Tilt has Night Vision up to 30 feet. Never miss a thing at night and still get the same high-quality video you’re used to.
INSTANT ACTIVITY ALERTS
No need to check your Kasa Spot Pan Tilt throughout the day. Get automatic alerts when it detects motion or sound. Take quick action when you see your pet on the couch, a roommate walking through your room, or an intruder enter your front door.
PROTECT EVERY PIXEL
All your video streams are protected with industry-standard 128-bit AES encryption with SSL/TLS right from the camera.
Why we love the Kasa 'Pan & Tilt’ Camera
Smart Cameras are perfect if you’ve got pets and would love to know what’s going on at home. With ‘Pan & Tilt’ this camera is perfect for open living spaces and can rotate to cover multiple points in your room. Providing 360 degree horizontal & 118 degree vertical views, it can monitor every angle of your room.
If your pet walks into your camera’s view, it will track your pet’s motion until they’ve found a spot to settle down. With two way audio you can also tell your 4-legged friend to get off the sofa from anywhere!
Product Description | TP-Link KC110 - network surveillance camera | Device Type | Network surveillance camera - pan / tilt | Audio | Yes: built-in speaker, two-way audio capability, built-in microphone | Dimensions (WxDxH) | 8.2 cm x 8.2 cm x 11.26 cm | Weight | 503 g | Connectivity Technology | Wireless | Camera | Colour - Day&Night | Frame Rate (max) | 15 frames per second | Motion Detection | Yes | Video Modes | 1080p | Optical Sensor Type | 1/2.7" | Focal Length | 3.97 mm | Lens Iris | F/2.2 | Panning Range (degree) | 360 | Tilting Range (degree) | 118 | Interfaces | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n | Cables Included | 1 - USB cable - external - 3.05 m | Voltage | DC 5 V | Features | Push Notification, reset button, Audio Detection, WPA, WPA2-PSK, WEP, motion detection | Manufacturer Warranty | 2-year warranty | Environmental Parameters (operating) | 0 °C - 40 °C; 10 - 95% (non-condensing) relative humidity |
General | |
Device Type | Network surveillance camera |
Audio Support | Yes: built-in speaker, two-way audio capability, built-in microphone |
Audio Formats | AAC |
Width | 8.2 cm |
Depth | 8.2 cm |
Height | 11.26 cm |
Weight | 503 g |
Camera | |
Type | Colour - Day&Night - pan / tilt |
Digital Video Format | H.264 |
Infrared LEDs | 6 |
Infrared Distance | 9.1 m |
Image Sensor | |
Type | 1/2.7" |
Lens Construction | |
Lens Iris | F/2.2 |
Panning | |
Tilting | |
Interfaces | |
Network Interface | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Network Protocols | TLS, SSL |
Miscellaneous | |
Included Accessories | Mounting kit |
Cables Included | 1 x USB cable - external - 3.05 m |
Compliant Standards | IC, FCC, RoHS, AES-128, TLS, SSL |
Power | |
Power Requirements | DC 5 V |
Power Device | Power adapter - external |
Software / System Requirements | |
OS Required | Android 5.0 or later, Apple iOS 10 or later |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Relative Humidity (operating) | 10 - 95% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
