TP LINK KC110 Kasa Smart Pan & Tilt Cam
36 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Motion tracking
  • Protect every pixel
  • Patrol mode
  • Two-way audio
  • Supports secure cloud storage to review and download your recordings from the Kasa app (additional charges may apply)
  • Type: Indoor Camera, Motion sensor
  • Compatible With: Alexa, Google Assistant, SmartThings
  • Stock Status: In Stock
Product codes
Bundle deals (2)
GET VOICE CONTROL WITH ALEXA
= £84.98
Save £15.00
GET VOICE CONTROL WITH GOOGLE ASSISTANT
= £93.99
Save £5.00
Up, Down, All-Around
Get the full picture of any space in your apartment, dorm or home with the Kasa Spot Pan Tilt. With a 360° horizontal view and 118° vertical view, the Pan Tilt has everything covered.
CRYSTAL CLEAR VIDEO
Sharp and clear 1080p full-HD provides high-quality video right in the palm of your hand.
PAN AND TILT
The Kasa Spot Pan Tilt indoor security camera is perfect for wide-open living spaces and can rotate to cover multiple points in your room. With 360° rotational and 118° vertical views, the pan tilt camera can monitor every angle of any room.
MOTION TRACKING
When motion is detected, the Kasa Spot Pan Tilt will continue tracking the activity until it has stopped even if is out of the camera’s normal view. If your four-legged friend walks into your camera’s view, the pan tilt camera will track their motion until they’ve found a spot to settle down in.
PATROL MODE
Set four distinct viewpoints in your living space so when action occurs in one of those areas the camera will automatically rotate to capture activity. Program your Pan Tilt camera to keep an eye on each region at intervals of your choosing.
24/7 LIVE VIEW
Keep an eye on what’s important to you real-time from anywhere with the Kasa Smart app. Even stream live video to any Alexa or Google Assistant supported display, like a Fire TV, Echo Show or Chromecast.
TWO-WAY AUDIO
Use crisp two-way audio to communicate with nosy roommates, family or even mischievous pets.
NIGHT VISION
Even in the dark, the Kasa Spot Pan Tilt has Night Vision up to 30 feet. Never miss a thing at night and still get the same high-quality video you’re used to.
INSTANT ACTIVITY ALERTS
No need to check your Kasa Spot Pan Tilt throughout the day. Get automatic alerts when it detects motion or sound. Take quick action when you see your pet on the couch, a roommate walking through your room, or an intruder enter your front door.
PROTECT EVERY PIXEL
All your video streams are protected with industry-standard 128-bit AES encryption with SSL/TLS right from the camera.
Why we love the Kasa 'Pan & Tilt’ Camera
Smart Cameras are perfect if you’ve got pets and would love to know what’s going on at home. With ‘Pan & Tilt’ this camera is perfect for open living spaces and can rotate to cover multiple points in your room. Providing 360 degree horizontal & 118 degree vertical views, it can monitor every angle of your room.
If your pet walks into your camera’s view, it will track your pet’s motion until they’ve found a spot to settle down. With two way audio you can also tell your 4-legged friend to get off the sofa from anywhere!
Product Description TP-Link KC110 - network surveillance camera
Device Type Network surveillance camera - pan / tilt
Audio Yes: built-in speaker, two-way audio capability, built-in microphone
Dimensions (WxDxH) 8.2 cm x 8.2 cm x 11.26 cm
Weight 503 g
Connectivity Technology Wireless
Camera Colour - Day&Night
Frame Rate (max) 15 frames per second
Motion Detection Yes
Video Modes 1080p
Optical Sensor Type 1/2.7"
Focal Length 3.97 mm
Lens Iris F/2.2
Panning Range (degree) 360
Tilting Range (degree) 118
Interfaces IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Cables Included 1 - USB cable - external - 3.05 m
Voltage DC 5 V
Features Push Notification, reset button, Audio Detection, WPA, WPA2-PSK, WEP, motion detection
Environmental Parameters (operating) 0 °C - 40 °C; 10 - 95% (non-condensing) relative humidity
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK KC110 Kasa Sma...
£49.99
