TP LINK KC110 Kasa Smart Spot Cam
£49.99
18 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered on Monday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Motion tracking
  • Protect every pixel
  • Patrol mode
  • Two-way audio
  • Stock Status: In Stock
Product codes
Sharp and clear Full HD provides high-quality video right in the palm of your hand. This indoor security camera is perfect for wide-open living spaces and can rotate to cover multiple points in your room. With 360° rotational and 118° vertical views, the pan tilt camera can monitor every angle of any room.
Product Description TP-Link KC110 - network surveillance camera
Device Type Network surveillance camera - pan / tilt
Audio Yes: built-in speaker, two-way audio capability, built-in microphone
Dimensions (WxDxH) 8.2 cm x 8.2 cm x 11.26 cm
Weight 503 g
Connectivity Technology Wireless
Camera Colour - Day&Night
Frame Rate (max) 15 frames per second
Motion Detection Yes
Video Modes 1080p
Optical Sensor Type 1/2.7"
Focal Length 3.97 mm
Lens Iris F/2.2
Panning Range (degree) 360
Tilting Range (degree) 118
Interfaces IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Cables Included 1 - USB cable - external - 3.05 m
Voltage DC 5 V
Features Push Notification, reset button, Audio Detection, WPA, WPA2-PSK, WEP, motion detection
Environmental Parameters (operating) 0 °C - 40 °C; 10 - 95% (non-condensing) relative humidity
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK KC110 Kasa Sma...
£49.99
