TP LINK KC115 Kasa Smart Pan & Tilt Cam with microSD slot
£49.99
19 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Crystal clear video 24/7
  • Pan and tilt
  • Motion tracking
  • Patrol mode
  • Real-time alerts
  • Two-way audio
  • Stock Status: In Stock
Product codes
Bundle deals (2)
KASA STARTER KIT - BULBS AND SMART PLUGS
= £99.98
Save £30.00
KASA SMART POWER STRIP
= £79.97
Save £5.00
Get the full picture of any space in your apartment, dorm or home with the Kasa Spot Pan Tilt. With a 360° horizontal view and 113° vertical view, the Pan Tilt has everything covered. Receive real-time alerts through the Kasa app when your camera detects motion or sound activity. With all videos stored locally on a MicroSD card, access your video history and live stream 1080p HD video to your smartphone, Alexa or Google Assistant supported display. The Pan Tilt also features advanced night vision to capture activity up to 30 ft. away in the dark and allows you to set custom activity zones around important areas to control what alerts you receive.
Product Description TP-Link Kasa Spot KC115 - network surveillance camera
Device Type Network surveillance camera - pan / tilt - indoor
Audio Yes: built-in speaker, two-way audio capability, built-in microphone
Dimensions (WxDxH) 8.2 cm x 8.2 cm x 11.26 cm
Weight 499 g
Connectivity Technology Wireless
Camera Colour - Day&Night
Max Resolution 1920 x 1080
Frame Rate (max) 15 frames per second
Motion Detection Yes
Video Modes 1080p
Optical Sensor Type 1/2.7"
Focal Length Control Fixed focal
Focal Length 3.97 mm
Lens Iris F/2.2
Panning Range (degree) 360
Tilting Range (degree) 113
Interfaces IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Intelligent Assistant Alexa ready, Google Assistant ready
Cables Included 1 - USB cable - external - 3.05 m
Voltage DC 5 V
Features Auto patrol, Push Notification, reset button, auto tracking, Smartphone Monitoring, Audio Detection, WPA, WPA2-PSK, WEP
Environmental Parameters (operating) 0 °C - 40 °C; 10 - 90% (non-condensing) relative humidity
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK KC115 Kasa Sma...
£49.99
