TP LINK KC120 Kasa Smart Cam
PRICE DROP
LIMITED TIME OFFER
SAVE! USUALLY £99.99!
£69.99
Delivery:
Standard: 1-3 working days
Express: Delivered on Tuesday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • 24/7, crystal clear live video, all-glass lens, 130° wide-angle view with 1080p resolution
  • Rich colors, balanced lighting and sharp video quality to make you feel like you're there
  • Night vision provides you with crystal clear night monitoring
  • Custom activity zones and notifications let you get alerts, that matter most to you
  • Records a clip every time it senses motion or detects a sound
  • 2-way audio with built-in microphone and speaker lets you keep in touch with your family
  • All your recordings are protected with AES 128-bit data encryption and SSL/TLS
  • Type: Indoor Camera
  • Compatible With: Alexa, Google Assistant
  • Stock Status: Clearance
Product codes
Protect your home and keep watch over those you care about most. Kasa cam is designed to deliver clear 1080p video the moment you start streaming, keeping you connected to your home anywhere you go.
Crystal Clear Video – Sharp and clear, wide-angle 1080p video makes sure you never miss a thing. Manually zoom in to get a closer look to what's going on. Even at night, the camera will detect activity 25 ft. (7.6 meters) away with Night Vision.
2-Way Audio – Communicate clearly with whoever you see on camera. Whether it’s your kids sneaking a cookie before dinner or your pets laying on the sofa, use 2-way audio to remind them to make better choices.
Easy Setup – Get the best angle and video from your Kasa Cam with an easy to adjust camera stand. Place it on a flat surface and start monitoring or use the magnetic base to affix it to your fridge.
Instant Notifications – With motion and sound detection, the Kasa Smart app alerts you of activity that matters and sends notifications straight to your smartphone.
Watch from Anywhere – Watch live or recorded video at any time on your smartphone with the free Kasa Smart app. Even stream live video to any Alexa or Google Assistant supported display, like a Fire TV or Google Chromecast.
Ready for Anything
You never want anything to happen to your home, but on the rare chance it does, Kasa Cam is ready to capture it.
Feel Like You’re There
Sharp and clear, wide-angle 1080p video makes sure you never miss a thing. Manually zoom in to get a closer look to what’s going on. Even at night, the camera will detect activity 25 ft. away with Night Vision.
See something special happening? Turn on the live stream and manually record what is happening.
Control with Your Voice
Kasa Cam makes it easy to keep an eye on your family with instant notifications and motion and audio detection. Control what alerts you receive by creating up to 4 custom activity zones, at no charge, around areas that are important to you.
Protect Every Pixel
We know your privacy is important to you, which is why every bit of your video is protected with industry-standard 128 bit AES encryption with SSL/TLS.
Product Description TP-Link KC120 Kasa Cam - network surveillance camera
Device Type Network surveillance camera - fixed
Audio Yes: built-in speaker, two-way audio capability, built-in microphone
Dimensions (WxDxH) 7.9 cm x 7.9 cm x 13.673 cm
Connectivity Technology Wireless
Camera Colour - Day&Night
Max Resolution 1920 x 1080
Frame Rate (max) 30 frames per second
Motion Detection Yes
Video Modes 720p
Optical Sensor Type 1/2.7"
Focal Length 3.21 mm
Lens Iris F/2.0
Interfaces IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Cables Included 1 - USB cable - external - 3.05 m
Voltage DC 5 V
Features Digital image rotation, Motion Detection Technology, Push Notification, LED indicator, reset button, Audio Detection, activity detection, wireless encryption, WPA, WPA2-PSK, WEP
Environmental Parameters (operating) 0 °C - 40 °C; 10 - 95% (non-condensing) relative humidity
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK KC120 Kasa Sma...
£69.99
