TP LINK KC200 Kasa Outdoor Cam
FREE DELIVERY
PRICE DROP
LIMITED TIME OFFER
USUALLY £99.99!
12 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered on Friday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Protect your outdoors
  • Made for everyday use
  • Protect every pixel
  • Supports secure cloud storage to review and download your recordings from the Kasa app (additional charges may apply)
  • Type: Outdoor Camera
  • Compatible With: Alexa, Google Assistant
  • Stock Status: In Stock
Product codes
Bundle deals (3)
GOOGLE NEST HUB SMART DISPLAY
= £118.99
Save £40.00
KASA STARTER KIT - BULBS AND SMART PLUGS
= £129.98
Save £30.00
KASA SMART POWER STRIP
= £104.97
Save £5.00
The Kasa cam outdoor is a full-featured weatherproof security camera that you can access from anywhere. Day or night, rain or shine, Kasa cam protects what you love.
Protect Your Outdoors
Use crisp 2-way audio to communicate with the delivery person at your front door or use the siren to scare away intruders.
Crystal Clear Video
Sharp and clear, wide-angle 1080P video makes sure you never miss a thing. Manually zoom in to get a closer look to what's going on, day or night.
Easy DIY Install
Get the best angle and video with your Kasa Cam Outdoor with an easy to follow installation process in the Kasa Smart app. The magnetic camera mount and mounting wall plate make for a quick set-up and allows you to configure your camera for the best view.
Watch from Anywhere
Watch live or recorded video at any time on your smartphone with the free Kasa Smart app. Even stream live video to any Alexa or Google Assistant supported display, e.g. Fire TV or Google Chromecast.
Instant Notifications
Get instant alerts straight to your smartphone whenever your Kasa Cam Outdoor detects any sound or motion.
Weatherproof
The Kasa Cam Outdoor’s IP65 rating ensures your device will be protected against rain and dust.
Product Description TP-Link Kasa KC200 - network surveillance camera
Device Type Network surveillance camera - fixed - outdoor - weatherproof
Audio Yes: built-in speaker, two-way audio capability, built-in microphone
Dimensions (WxDxH) 7.395 cm x 7.355 cm x 8.628 cm
Weight 310 g
Connectivity Technology Wireless
Camera Colour - Day&Night
Max Resolution 1920 x 1080
Frame Rate (max) 30 frames per second
Motion Detection Yes
Video Modes 720p, 1080p, 360p
Optical Sensor Type 1/2.7"
Focal Length Control Fixed focal
Focal Length 3.21 mm
Lens Iris F/2.0
Interfaces IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Intelligent Assistant Google Assistant, Alexa
Cables Included 1 - USB cable - external - 3.05 m
Voltage DC 5 V
Features LED indicator, reset button, Audio Detection, built-in siren, WPA, WPA2-PSK, WEP
Environmental Parameters (operating) -20 °C - 43 °C; 10 - 95% (non-condensing) relative humidity
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK KC200 Kasa Out...
£79.99
