TP LINK KL110 Kasa Smart Wifi Light Bulb Dimmable
£24.99
40 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Dimmable
  • No hub required
  • Control from anywhere
  • Voice control
  • Scenes and schedules
  • Energy efficient
Product codes
Kasa Smart Wi-Fi Light Bulb, Dimmable
Control the mood with your Kasa Smart dimmable light bulb.
Dimmable
With a dimming range from 1% up to 100%, the Kasa Smart Wi-Fi Light Bulb, Dimmable helps you set the right brightness for any mood or activity.
Grouping
Use the Grouping feature on the Kasa Smart app to combine your devices together for unified control with one single tap on your smartphone. Combine your living room bulbs, plugs and light switches together for an easier way to turn them on when you get home.
Control From Anywhere
Control your Kasa Smart lighting from anywhere with the highly-rated Kasa Smart app (available for iOS, Android). Make sure you turned your bedroom lights off from the office or turn your living room lights on before you get home.
Voice Control
Use simple voice commands to control all of your Kasa Smart light switches or light bulbs with any Alexa, Google Assistant or Microsoft Cortana smart speaker. Turn on kitchen lights when your hands are full, let your voice assistant know to dim your lights, even turn off hallway lights as you're walking to bed.
No Hub Required
Connect your Kasa Smart dimmable light bulb directly to your home’s secure Wi-Fi network. No need for a hub or extra equipment.
Energy Efficient
The Title 20 and Energy Star certified light bulb reduces consumption by up to 80% without losing brightness or quality, while saving you money.
Product Description TP-Link KL110 - LED light bulb
Light Bulb Type LED light bulb
Shape A19
Socket Type E26
Wattage 10 W
Wattage Equivalent 60 W
Colour of Illumination White light
Colour Temperature 2700 K
Luminous Power 800 lumens
Beam Angle 220 degree(s)
Dimmable Yes
Voltage Required AC 120 V
Frequency Required 50/60 Hz
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK KL110 Kasa Sma...
£24.99
