TP LINK KL110B Dimmable Kasa Smart Bulb - Bayonet
£27.99
Delivery:
Standard: 1-3 working days
Key features
  • No hub required
  • Energy efficient
  • Type: Light bulb
  • Compatible With: Alexa, Cortana, Google Assistant
  • Stock Status: In Stock
Product codes
Kasa Smart Light Bulb, Dimmable
Dimmable
Kasa Smart’s dimmable light bulb has a dimming range from 1% to 100%. Set the right brightness for any mood or activity. Turn your bulb to full brightness to get your kids up in the morning or dim it enough for them to fall asleep at night.
No Hub Required
The Kasa Smart Wi-Fi Light Bulb, Dimmable connects to your home’s secure Wi-Fi network. No need for a hub or extra equipment.
Control from Anywhere
Control your smart light bulb from anywhere with your smartphone using the Kasa Smart app (iOS, Android). Smoothly dim the brightness of your light bulb from anywhere with the app.
Voice Control
Use simple voice commands to control your Kasa Smart dimmable light bulb with any Amazon Alexa, Google Assistant or Microsoft Cortana. Just tell your voice assistant to dim your lights and set the perfect mood for movie night.
Scenes and Schedules
Use your Kasa Smart app to schedule your light bulb to automatically switch on and off when you’re home or away. Combine all your lights with other Kasa Smart devices in a Scene and control them with a single button. Dim all your lights and set the scene for a romantic dinner or a movie night.
Energy Consumption Class A+
Kasa Smart's dimmable light bulb is certified to drive down energy consumption without losing quality.
Product Description TP-Link Kasa Smart KL110B - LED light bulb
Light Bulb Type LED light bulb
Shape A60
Socket Type E27
Wattage 10 W
Wattage Equivalent 60 W
Light Bulb Energy Efficiency Class A+
Colour Temperature 2700 K
Luminous Power 800 lumens
Beam Angle 230 degree(s)
Dimmable Yes
Voltage Required AC 220 - 240 V
Frequency Required 50/60 Hz
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK KL110B Dimmabl...
£27.99
