TP LINK KL120 Smart Light Bulb Tuneable
Key features
  • Tunable white
  • No hub required
  • Control from anywhere
  • Voice control
  • Auto white
  • Scenes and schedules
  • Energy efficient
Product codes
Kasa Smart Light Bulb, Tuneable
Tunable White – Create cozy warm whites to relax after a long day or energetic bright whites when you need a boost with Kasa Smart’s tunable white LED light bulb. Tune the appearance from a soft white (2700k) to a bright light (6500K).
No Hub Required – Kasa Smart’s tunable white LED light bulb connects to your home’s secure Wi-Fi network. No need for a hub or extra equipment.
Control from Anywhere – Control your smart light bulb from anywhere with your smartphone using the free Kasa Smart app (iOS, Android). Turn your light bulb on if it’s getting late so you’ll arrive to a well-lit home.
Voice Control - Use simple voice commands to control Kasa Smart’s tunable white LED light bulb with any Alexa, Google Assistant or Microsoft Cortana. Just tell your voice assistant to turn the bulb on and off or set schedules so it turns on when you wake up or to a soft white when you want to relax.
Auto White – Set your bulb to automatically adjust its color temperature to match natural light patterns from dawn to dusk.
Scenes and Schedules – Use your Kasa Smart app to schedule your light bulb to automatically switch on and off when you’re home or away. Combine all your lights with other Kasa Smart devices in a Scene and control them at your fingertips.
Energy Consumption Class A+ – The light bulb reduces consumption without losing brightness or quality, while saving you money.
Set and Enjoy
Match natural light patterns with your Kasa Smart tunable white LED light bulb.
Tunable White
Set your lights to a soft glow in the morning or tune them to full brightness at night with Kasa Smart’s tunable white LED light bulb. Control from the Kasa Smart app or use simple voice commands with Alexa, Google Assistant, or Microsoft Cortana.
Schedules
Scenes
You like your light bright while they like it dim — but you both hate adjusting every bulb each time. Solve both problems with Kasa Smart. Create multiple scenes with different settings and tap yours when you want the light your way.
Your Voice Has Power
Control your device with simple voice commands and an Amazon Alexa, Google Assistant, or Microsoft Cortana.
Product Description TP-Link KL120 - LED light bulb
Light Source Type LED light bulb
Shape A19
Socket Type E26
Wattage 10 W
Wattage Equivalent 60 W
Colour of Illumination Soft white/daylight
Colour Temperature 2700/5000 K
Luminous Power 800 lumens
Beam Angle 220 degree(s)
Dimmable Yes
Intelligent Assistant Cortana, Google Assistant, Alexa
Platform Kasa
Communications Technology Wi-Fi
Voltage Required AC 120 V
Frequency Required 50/60 Hz
Warranty 2 year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
