TP LINK KL130 Multicolour Smart Bulb - Screw
10 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Multicolor
  • No hub required
  • Control from anywhere
  • Voice control
  • Auto white
  • Scenes and schedules
  • Type: Light bulb
  • Compatible With: Alexa, Cortana, Google Assistant
  • Stock Status: In Stock
Product codes
Bundle deals (2)
KASA STARTER KIT - BULBS AND SMART PLUGS
= £79.97
Save £30.00
KASA SMART POWER STRIP
= £59.96
Save £5.00
Kasa Smart Light Bulb, Multicolor
Multicolor – With a wide range of colors and dimming capabilities, Kasa Smart’s multicolor light bulb offers endless lighting possibilities. You can choose a light for everything from a dinner party to a late-night study session.
No Hub Required – Kasa Smart’s multicolor light bulb connects to your home’s secure Wi-Fi network. No need for a hub or extra equipment.
Control from Anywhere – Control your smart light bulb from anywhere with your smartphone using the free Kasa Smart app (iOS, Android). Dim, turn on or off or change the colors of your light bulb remotely at your fingertips.
Voice Control - Use simple voice commands to control your Kasa Smart multicolor light bulb with any Amazon Alexa, Google Assistant or Microsoft Cortana. Have your voice assistant change the color to help you wake up in the morning or adjust the brightness to help your kids settle down in the evening.
Auto White – Set your bulb to automatically adjust its color temperature to match natural light patterns from dawn to dusk.
Scenes and Schedules – Use your Kasa Smart app to schedule your light bulb to automatically switch on and off when you’re home or away. Combine all your lights with other Kasa Smart devices in a Scene and control them with a single button. Create a party scene and have your smart lights change to any color you want.
Energy Consumption Class A+ – Kasa Smart's multicolor light bulb is certified to drive down energy consumption without losing quality.
Add Color to Your Life
Create the perfect ambiance with your Kasa Smart multicolor light bulb.
Multicolor
Schedules
Control your smart light bulb from anywhere with your smartphone using the Kasa Smart app (iOS, Android). Smoothly dim the brightness of your light bulb from anywhere with the app.
Scenes
You like your light bright while they like it dim — but you both hate adjusting every bulb each time. Solve both problems with Kasa Smart. Create multiple scenes with different settings and tap yours when you want the light your way.
Your Voice Has Power
Control your device with simple voice commands and an Amazon Alexa, Google Assistant, or Microsoft Cortana.
Product Description TP-Link KL130 - LED light bulb
Light Source Type LED light bulb
Shape A19
Socket Type E26
Wattage 10.5 W
Wattage Equivalent 60 W
Light Bulb Energy Efficiency Class A+
Colour of Illumination Multicolour light
Colour Temperature 2500-9000 K
Luminous Power 800 lumens
Beam Angle 220 degree(s)
Dimmable Yes
Intelligent Assistant Cortana, Google Assistant, Alexa
Platform Kasa
Communications Technology Wi-Fi
Voltage Required AC 120 V
Frequency Required 50/60 Hz
Warranty 2 year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK KL130 Multicol...
£29.98
