TP LINK KL50 Filament Smart Bulb (white) - Screwfit E27
19 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Control from anywhere
  • Soft white
  • Dimmable
  • No hub required
  • Device grouping
  • Type: Light bulb
  • Compatible With: Alexa, Google Assistant
  • Stock Status: In Stock
Product codes
Bundle deals (2)
GET VOICE CONTROL WITH ALEXA
= £52.97
Save £15.00
GET VOICE CONTROL WITH GOOGLE ASSISTANT
= £61.98
Save £5.00
Control your LED filament smart bulb from anywhere with your smartphone using the Kasa Smart app (iOS, Android). Turn your lights on and off from the office, check in and make sure you turned off your kitchen lights, even schedule lights to turn on before you get home.
Kasa Filament Smart Bulb, Soft White's 2700K temperature works well for any environment. Dim your light to any level of brightness for the right ambiance for a multitude of occasions. The dimmer the bulb, the more you can see the filament design inside.
Kasa Smart's LED filament bulb has an expansive dimming range that can be controlled conveniently with the Kasa Smart app. Turn your filament bulb to full brightness for a well-lit vanity or dim it down for a dinner party.
Product Description TP-Link Kasa Smart KL50 - LED filament light bulb
Light Source Type LED filament light bulb
Shape A60
Socket Type E27
Wattage 7 W
Colour of Illumination Soft white light
Colour Temperature 2700 K
Luminous Power 800 lumens
Beam Angle 290 degree(s)
Dimmable Yes
Intelligent Assistant Google Assistant, Alexa - indirect
Platform Kasa
Communications Technology Wi-Fi
Voltage Required AC 220 - 240 V
Frequency Required 50/60 Hz
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK KL50 Filament...
£17.98
