TP LINK KL50B Filament Smart Bulb (white) - Bayonet B22
Delivery:
Standard: 1-3 working days
Key features
  • Control from anywhere
  • Dimmable
  • Device grouping
  • Voice control
  • Type: Light bulb
  • Compatible With: Alexa, Google Assistant
  • Stock Status: In Stock
Product codes
Bundle deals (2)
GET VOICE CONTROL WITH ALEXA
= £52.97
Save £15.00
GET VOICE CONTROL WITH GOOGLE ASSISTANT
= £61.98
Save £5.00
Control from Anywhere
Control your LED filament smart bulb from anywhere with the Free Kasa Smart app (iOS, Android).
Soft White
Kasa Filament Smart Bulb, Soft White’s 2700K temperature works well for any environment. Adjust your light to any level of brightness for the right ambiance.
Dimmable
An expansive dimming range that can be controlled conveniently with the Kasa Smart app.
No Hub Required
Connects directly to your home’s secured Wi-Fi network. No need for a hub or extra equipment.
Device Grouping
Combine your smart filament bulb with other Kasa Smart devices for seamless control with a single tap on your smartphone.
Voice Control
Use simple voice commands with Alexa and Google Assistant to dim your lights and set the perfect mood for movie night.
Energy Monitoring
Track the real-time energy consumption with the Kasa Smart app.
Set Schedules
Use your Kasa Smart app to schedule your LED filament light bulb to turn on and off at set times throughout the day.
Product Description TP-Link Kasa Smart KL50B - LED filament light bulb
Light Source Type LED filament light bulb
Shape A60
Socket Type B22
Wattage 7 W
Colour of Illumination Soft white light
Colour Temperature 2700 K
Luminous Power 800 lumens
Beam Angle 290 degree(s)
Dimmable Yes
Intelligent Assistant Google Assistant, Alexa - indirect
Platform Kasa
Communications Technology Wi-Fi
Voltage Required AC 220 - 240 V
Frequency Required 50/60 Hz
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
TP LINK KL50B Filament...
£17.98
