TP LINK KL60 Kasa Smart Bulb - Screwfit
PRICE DROP
LIMITED TIME OFFER
USUALLY £19.99!
13 left in stock
Delivery:
Standard: 1-3 working days
Express: Delivered on Tuesday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Dimmable
  • Device grouping
  • Voice control
  • Energy monitoring
  • Type: Light bulb
  • Compatible With: Alexa, Google Assistant
  • Stock Status: Clearance
Product codes
Bundle deals (1)
GOOGLE NEST HUB SMART DISPLAY
= £53.98
Save £40.00
Kasa Filament Smart Bulb, Warm Amber
Control from Anywhere
Control your LED filament smart bulb from anywhere with your smartphone using the Kasa Smart app (iOS, Android). Turn your lights on and off from the office, check in and make sure you turned off your kitchen lights, even schedule lights to turn on before you get home.
Warm Amber
The glow of the Kasa Filament Smart Bulb, Warm Amber illuminates a 2000K light that is suitable for homes, restaurants, cafes and wherever a warm, romantic ambiance is desirable.
Dimmable
Kasa Smart’s LED filament bulb has an expansive dimming range that can be controlled conveniently with the Kasa Smart app. From entertaining guests to a romantic dinner, this bulb can dim to fit any environment.
No Hub Required
The Kasa Filament Smart Bulb, Warm Amber connects directly to your home’s secure WiFi network. No need for a hub or extra equipment. All you need is your smartphone, the Kasa Smart app and a WiFi connection to start remotely controlling your smart bulb.
Device Grouping
Use Grouping to combine your smart filament bulb with other Kasa Smart devices for seamless control with a single tap of your smartphone. Put all of your amber lights into a single group and dim them all at once for the perfect romantic dinner lighting.
Voice Control
Use simple voice commands to control your Kasa Filament Smart Bulb with any Alexa or Google Assistant. Just tell your voice assistant to dim your lights and set the perfect mood for movie night.
Energy Monitoring
Using the Kasa Smart app, you can check on your LED filament bulb from anywhere to see how much energy is being consumed. Turn it off remotely to stop any consumption.
Set Schedules
Use your Kasa Smart app to schedule your LED filament light bulb to turn on and off around your daily routine.
Quick and Easy
Be up and lit with your new smart bulb! It’s as easy as 1-2-3 or A-B-C! Screw your bulb in, follow the simple setup in the Kasa Smart app, name it and get to glowing.
Product Description TP-Link Kasa Smart KL60 - LED filament light bulb
Light Source Type LED filament light bulb
Shape A60
Socket Type E27
Wattage 5 W
Colour of Illumination Amber light
Colour Temperature 2000 K
Luminous Power 450 lumens
Beam Angle 290 degree(s)
Dimmable Yes
Intelligent Assistant Google Assistant, Alexa - indirect
Platform Kasa
Communications Technology Wi-Fi
Voltage Required AC 220 - 240 V
Frequency Required 50 - 60 Hz
Warranty 2 year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK KL60 Kasa Smar...
£14.98
