TP LINK KP303 Kasa Smart WiFi Power Strip - 3 Outlets, 2 USB...
FREE DELIVERY
TP LINK KP303 Kasa Smart WiFi Power Strip - 3 Outlets, 2 USB Ports
19 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 3 smart outlets + 2 USB ports
  • Surge protection
  • Control from anywhere
  • Voice control
  • Set schedules & timers
  • Type: Smart plug
  • Compatible With: Alexa, Google Assistant
  • Stock Status: In Stock
Product codes
Bundle deals (2)
GET VOICE CONTROL WITH ALEXA
= £69.98
Save £15.00
GET VOICE CONTROL WITH GOOGLE ASSISTANT
= £78.99
Smart Controls with Surge Protection in One
Kasa Smart Wi-Fi Power Strip
Individually Control 3 Smart Outlets
With 3 smart outlets that can be separately managed and 2 always-on USB ports, the Kasa Smart Wi-Fi Power Strip meets your diverse needs like supporting multiple appliances from lamps to humidifiers and more simultaneously or independently.
Control from Anywhere
Control up to 3 devices individually or collectively with the Kasa Smart app. Remotely turn off/on plugged-in devices such as lamps, fans, heaters and other devices.
Voice Control
Compatible with Alexa and Google Assistant. Free up your hands by using voice commands to control plugged in devices.
Set Schedules and Timers
Create schedules/timers to turn outlets on/off at specific times to improve convenience and efficiency, manage complicated set-ups like high-end fish tanks, and cut down on power consumption.
Space Saving Design
The right-angled flat plug is designed to leave other outlets free and easily fit behind furniture and in tight spaces.
Surge Protection
Surge protection shields sensitive electronics and appliances from sudden electrical surges and spikes, including those caused by lightning or short circuits. Keep your devices safe during thunderstorms.
No Hub Required
Connect to any secured 2.4 GHz wireless network to control directly. No need for a separate hub or extra equipment.
Your Home. One App.
Turn your home into a true smart home with Kasa Smart. Automate your lights and appliances with smart plugs and bulbs. Secure your home with Kasa Cameras. Control it all from the Kasa Smart app.
Product Description TP-Link Kasa KP303 - smart power strip
Device Type Smart power strip - external
Weight 470 g
Input Connectors 1 x power 3-pole
Output connectors 3 x power (surge) , 2 x 4 pin USB Type A - 5 V 2.4 A
Intelligent Assistant Google Assistant, Alexa
Networking IEEE 802.11 b/g/n
System Requirements Android 5.0 or later, Apple iOS 10 or later
Dimensions (WxDxH) 26 cm x 6.34 cm x 3.86 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK KP303 Kasa Sma...
£34.99
