TP LINK LB100 Smart WiFi LED Bulb with Dimmable Light (E27+Ba...
TP LINK LB100 Smart WiFi LED Bulb with Dimmable Light (E27+Bayonet)
£21.99
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • No extra hardware required - convenient smart Wi-Fi bulb with no extra hardware required
  • Anywhere and anytime - easy setup and control from anywhere
  • Save energy - save energy without sacri­ficing brightness or quality
  • Dimmable light - dimming flexible white light for customized lighting
  • Type: Light bulb
  • Compatible With: Alexa
  • Stock Status: Clearance
Product codes
Bundle deals (2)
GET VOICE CONTROL WITH ALEXA
= £56.98
Save £15.00
GET VOICE CONTROL WITH GOOGLE ASSISTANT
= £65.99
Save £5.00
Light. Your Way.
LB100 - Smart Wi-Fi LED Bulb with Dimmable Light
No Hub Required – Connect the bulb to your Wi-Fi at home
Manage Remotely – Easy setup and control from anywhere with the free Kasa app (iOS, Android)
Dimmable Light – Dimming flexible white light for customized lighting
Voice Control – Pair to Amazon Alexa and the Google Assistant to enable voice control
Save Energy – Save energy without sacrificing brightness or quality
Compatibility – Compatible with Android, iOS and Amazon Alexa and the Google Assistant
Control from Anywhere
Using Wi-Fi, you can control the LB100 without a hub or additional hardware. Just open the Kasa app on your smartphone to manage the smart bulb remotely, anytime and anywhere.
Compatible with Android, iOS, Amazon Alexa and the Google Assistant
The Kasa app works with Android (4.1 and higher) and iOS (iOS 8 and higher) devices so you can control your home right from your smartphone or tablet. You can also use Kasa app to pair TP-Link smart home products with any Amazon Echo, Dot, Tap and the Google Assistant for voice control, giving you the ability to control your home with voice commands.
Save Energy with LED Bulb
The LB100 saves energy without sacrificing brightness or quality, and lasts up to 13.7 years.
Estimated energy cost:
Standard 50W Incandescent Bulb: £6.02 per year
TP-LINK LB100 Smart Wi-Fi LED Bulb (50W equiv.): £0.84
Schedule Your Light
Set schedules to turn on/off the Smart Bulbs at any chosen time for your convenience. For example, you can set the bulbs to turn on every morning to wake you up or every dusk to light up your room automatically.
Set the Scene. Any Scene
Save your light settings as different scenes to enjoy instant access to them. Smart Wi-Fi bulbs can be controlled individually or as a group, letting you set the ideal mood for your lifestyle and preferences.
Reading scene - Create lighting that calms and helps you see clearly.
Movie scene - Lower the lights to immerse yourself in a film.
Good Night scene - Turn off all your lights, or keep a few on for moving easily in the night.
Product Description TP-LINK LB100 - LED light bulb
Light Bulb Type LED light bulb
Socket Type E27 (also includes B22 Bayonet Adaptor)
Wattage 8 W
Wattage Equivalent 50 W
Colour Temperature 2700 K
Luminous Power 600 lumens
Beam Angle 270 degree(s)
Dimmable Yes
Voltage Required AC 108 - 132 V
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK LB100 Smart Wi...
£21.99
