TP LINK LB110 Smart Wi-Fi E27 LED Bulb with Dimmable Light
£39.99
10 left in stock
Delivery:
Standard: 1-3 working days
Key features
  • Manage remotely
  • Fine-tune your lighting
  • Enjoy peace of mind
  • Away mode
  • Type: Light bulb
  • Compatible With: Alexa
  • Stock Status: Clearance
Product codes
Documents
Bundle deals (2)
GET VOICE CONTROL WITH ALEXA
= £74.98
Save £15.00
GET VOICE CONTROL WITH GOOGLE ASSISTANT
= £83.99
Control your lighting from anywhere with the LB110. The smart bulb installs as easily as a standard light bulb, and connects to your home Wi-Fi in no time through the free Kasa app. Kasa also lets you manage your lights with your smartphone or tablet, including adjusting brightness, setting schedules and scenes, and tracking energy used. For added convenience, you can use your voice to control the LB110 when paired with Amazon Alexa.
Highlights:
* Works with Amazon Alexa for voice control (Alexa device sold separately)
* 60 Watt Equivalent, 2700K Soft White
* Control your lights from anywhere with your tablet or smartphone using the free kasa app (Android 4.1 or higher / iOS 8 or higher)
* Dim brightness to customize Lighting and suit your mood
* Set schedules, timers, and countdowns and have your lights work around your life
* No hub required; works with your Wi-Fi router
Package Contents:
* Smart Wi-Fi LED Bulb LB110
* Quick Installation Guide
IFTTT
IFTTT is a free platform that helps you do more with all your apps and devices. Kasa by TP-Link is a leading smart home system that includes Kasa Smart Plugs, Smart Bulbs, Smart Switches and more. It works with other leading smart home products such as Amazon Echo, Google Home, and more. Now with IFTTT, you can also create personalized Applets that trigger automatic actions on your Kasa devices.
Our favourite TPLink Kasa Applet: Turn on your lights at sunset
Turn on your light within 15 minutes of the sunset at your location - by TP-Link Kasa - https://ifttt.com/applets/fjksUhKu-turn-on-your-light-at-sunset
See all TPLink Applets on IFTTT here: https://ifttt.com/kasa
Product Description TP-Link LB110 - LED light bulb
Light Source Type LED light bulb
Shape A19
Socket Type E27
Wattage 10 W
Wattage Equivalent 60 W
Light Bulb Energy Efficiency Class A+
Colour of Illumination Warm white light
Colour Temperature 2700 K
Luminous Power 800 lumens
Beam Angle 180 degree(s)
Dimmable Yes
Intelligent Assistant Alexa
Communications Technology Wi-Fi
Voltage Required AC 220 - 240 V
Frequency Required 50 Hz
Resources
The following resources are available for the TP LINK LB110 Smart Wi-Fi E27 LED Bulb with Dimmable Light
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK LB110 Smart Wi...
£39.99
