TP LINK LB120 Smart Wi-Fi E27 (with B22 convertor) LED Bulb w...
FREE DELIVERY
TP LINK LB120 Smart Wi-Fi E27 (with B22 convertor) LED Bulb with Tuneable White Light
Key features
  • Manage remotely
  • Fine-tune lighting
  • Circadian mode
  • Monitor power
  • Save energy
Product codes
Documents
Control your lighting from anywhere with the LB120. The smart bulb installs as easily as a standard light bulb, and connects to your home Wi-Fi in no time through the free Kasa app. Kasa lets you manage your lights with your smartphone or tablet, including adjusting brightness, setting schedules and scenes, and tracking energy used.
The LB120 also lets you tune its white temperature to create lighting suited to your mood, from bright daylight to soft, relaxing whites. For added convenience, you can control the LB120 with your voice when paired with Amazon Alexa.
Highlights:
* Control your lights from anywhere with your tablet or smartphone using the free Kasa app (iOS, Android)
* Dim brightness and fine-tune light appearance from soft white (2700k) to daylight (6500k)
* Pair to Amazon Alexa and to enable voice control
* Automatically matches light appearance to time of day
* Track real-time energy used to stay informed
Package Contents:
* Smart Wi-Fi LED Bulb LB120
* Quick Installation Guide
IFTTT
IFTTT is a free platform that helps you do more with all your apps and devices. Kasa by TP-Link is a leading smart home system that includes Kasa Smart Plugs, Smart Bulbs, Smart Switches and more. It works with other leading smart home products such as Amazon Echo, Google Home, and more. Now with IFTTT, you can also create personalized Applets that trigger automatic actions on your Kasa devices.
Our favourite TPLink Kasa Applet: Turn on your lights at sunset
Turn on your light within 15 minutes of the sunset at your location - by TP-Link Kasa - https://ifttt.com/applets/fjksUhKu-turn-on-your-light-at-sunset
See all TPLink Applets on IFTTT here: https://ifttt.com/kasa
Product Description TP-Link LB120 - LED light bulb
Light Bulb Type LED light bulb
Usage Modes Anti burglar
Bulb Finish Frosted
Socket Type E27
Wattage 10 W
Wattage Equivalent 60 W
Colour of Illumination Warm white/daylight
Colour Temperature 2700-6500 K
Luminous Power 800 lumens
Beam Angle 180 degree(s)
Dimmable Yes
Voltage Required AC 120 V
Frequency Required 60 Hz
Resources
The following resources are available for the TP LINK LB120 Smart Wi-Fi E27 (with B22 convertor) LED Bulb with Tuneable White Light
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK LB120 Smart Wi...
