TP LINK LiteWave 8-Port 10/100M Desktop Switch
£8.62
Delivery:
Notify me
Key features
  • 8× 10/100Mbos Auto-Negotiation RJ45 port, supporting Auto-MDI/MDIX
  • Green Ethernet technology saves power
  • IEEE 802.3X flow control provides reliable data transfer
  • Plastic casing and desktop design
  • Plug and play, no configuration needed
  • Fanless design ensures quiet operation
  • Type: Fast Ethernet
  • Ports: 8
  • Managed: No
Product codes
The TP-Link LiteWave Series Unmanaged Switches provide easy and affordable way to expand your wired network. They are easy to use and reliable. With these plug-and-play switches, you can expand your network connections to multiple devices instantly. With all ports support Auto-MDI/MDIX, there's no need to worry about the type of cable to use.
The LiteWave Series also supports energy-efficient technology, helping you save power and money. Power consumption automatically adjusts according to link status and cable length, allowing you to expand your network while minimizing your carbon footprint. Save the planet and lower your energy bills - it's a win-win!
The LS1008 is fully compatible with networked devices such as computers, printers, webcams, IPTVs. It has a wide range of application scenarios and is suitable for networking in school dormitories, surveillance, homes, and small businesses.
Product Description TP-Link LiteWave LS1008 - switch - 8 ports - unmanaged
Device Type Switch - 8 ports - unmanaged
Subtype Fast Ethernet
Ports 8 x 10/100
Performance Switching capacity: 1.6 Gbps , Forwarding performance: 1.2 Mpps
MAC Address Table Size 2K entries
Jumbo Frame Support 2000 bytes
Features Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, plastic housing, fanless, Back Pressure Support, Green Technology
Compliant Standards IEEE 802.3u, IEEE 802.3i, IEEE 802.3x
Dimensions (WxDxH) 12.46 cm x 4.87 cm x 2.28 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£8.62
Notify me
