TP LINK LiteWave 8-Port Gigabit Desktop Switch
£14.62
47 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 8× 10/100/1000Mbos Auto-Negotiation RJ45 port, supporting Auto-MDI/MDIX
  • Green Ethernet technology saves power
  • IEEE 802.3X flow control provides reliable data transfer
  • Plastic casing, desktop or wall-mounting design
  • Plug and play, no configuration needed
  • Fanless design ensures quiet operation
  • Type: Gigabit Ethernet
  • Ports: 8
  • Managed: No
  • Stock Status: In Stock
Product codes
The TP-Link LiteWave Series Unmanaged Switches provide easy and affordable way to expand your wired network. They are easy to use and reliable. With these plug-and-play switches, you can expand your network connections to multiple devices instantly. With all ports support Auto-MDI/MDIX, there's no need to worry about the type of cable to use.
Increase the speed of your network with the LS1008G 8-port Gigabit desktop switch. Non-blocking, 8× 10/100/1000Mbps ports enable instant transferring of large, bandwidth intensive files without interference.
Product Description TP-Link LiteWave LS1008G - switch - 8 ports - unmanaged
Device Type Switch - 8 ports - unmanaged
Subtype Gigabit Ethernet
Ports 8 x 10/100/1000
Performance Switching capacity: 10 Gbps , Forwarding performance: 11.9 Mpps
MAC Address Table Size 4K entries
Jumbo Frame Support 16KB
Features Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, plastic housing, fanless, Green Technology
Compliant Standards IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.3x
Dimensions (WxDxH) 12.7 cm x 6.65 cm x 2.3 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK LiteWave 8-Por...
£14.62
