The TP-Link LiteWave switches provide easy and affordable way to expand your wired network. They are easy to use and reliable.
Product Description | TP-Link LiteWave LS108G - switch - 8 ports - unmanaged | Device Type | Switch - 8 ports - unmanaged | Subtype | Gigabit Ethernet | Ports | 8 x 10/100/1000 | Performance | Forwarding performance: 11.9 Mpps | MAC Address Table Size | 4K entries | Jumbo Frame Support | 16KB | Features | Auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, store and forward, Quality of Service (QoS), fanless, loop prevention | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 801.1p | Power | AC 220 V (50 Hz) | Dimensions (WxDxH) | 15.8 cm x 9.91 cm x 2.5 cm |
General | |
Enclosure Type | Desktop |
Status Indicators | Port status, power |
Expansion / Connectivity | |
Interfaces | 8 x 1000Base-T RJ-45 |
Power | |
Power Device | External power adapter |
Voltage Required | AC 220 V (50 Hz) |
Power Consumption Operational | 3.7 Watt |
Miscellaneous | |
Compliant Standards | FCC, RoHS |
Dimensions & Weight | |
Width | 15.8 cm |
Depth | 9.91 cm |
Height | 2.5 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 5 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
