TP LINK LTE-Advanced Mobile Wi-Fi
£80.66
Delivery:
Standard: 1-3 working days
Key features
  • 4G LTE supported with up to 150 Mbps download and 50 Mbps upload speeds
  • Supports up to 15 devices simultaneously
  • All useful information at a glance with screen display
  • 2550 mAh battery for long hours of working
  • Selectable dual band Wi-Fi
  • Equipped with a micro SD card slot
  • Stock Status: In Stock
Product codes
TP-LINK's M7350 is at the forefront of wireless 4G sharing. Just insert a 4G SIM card into the device to instantly establish a selectable dual band Wi-Fi hotspot. With up to 150 Mbps download and 50 Mbps upload speeds, the M7350 is able to provide 4G wireless sharing to up to 15 users simultaneously. Its pocket-sized design and powerful 2550 mAh internal battery make it an ideal travel companion, allowing users to work or play for long hours. With its innovative TFT-display, users can have a much more intuitive view of the device's operating status, such as signal strength, network type (4G/3G/2G), Wi-Fi status, messages, Internet, traffic statistics and battery life.
Product Description TP-Link M7350 - V4 - mobile hotspot - 4G LTE
Device Type Mobile hotspot
Form Factor External
Max Transfer Rate 150 Mbps
Cellular Protocol GSM, GPRS, UMTS, EDGE, HSPA, LTE, DC-HSPA+
Mobile Band GSM 850/900/1800/1900 / UMTS 900/2100 / LTE 800/900/1800/2100/2600
Networking IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Battery 2000 mAh - up to 8 hrs
System Requirements Apple MacOS, Android, Apple iOS, Microsoft Windows Vista / XP / 7 / 8, Windows 10
Dimensions (WxDxH) 10.6 cm x 6.6 cm x 1.6 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK LTE-Advanced M...
£80.66
