We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
An EAP in each room allows guests to enjoy their own private Wi-Fi network that's fast, delivering a strong signal, and providing corner to corner coverage.
Product Description | TP-Link Omada EAP235-Wall - radio access point - Wi-Fi 5 | Device Type | Radio access point | Form Factor | Wall mountable | Data Link Protocol | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2 | Frequency Band | 2.4 GHz, 5 GHz | Capacity | Maximum number of configured SSIDs (2.4 Ghz): 8 , Maximum number of configured SSIDs (5 Ghz): 8 | Included Accessories | Wall mounting kit | OS Required | Microsoft Windows XP / Vista / 7 / 8 / 10 | Power Over Ethernet (PoE) Supported | PoE+ | Dimensions (WxDxH) | 8.6 cm x 2 cm x 14.3 cm |
General | |
Width | 8.6 cm |
Depth | 2 cm |
Height | 14.3 cm |
Networking | |
Connectivity Technology | Wireless |
Remote Management Protocol | SNMP 1, SNMP 2c, HTTP, HTTPS |
Wi-Fi Rating | AC1200 |
Features | Load balancing, E-mail alert, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), reset button, rogue access point detection, MU-MIMO technology, beamforming technology, band steering, SSID to VLAN mapping, rate limit, VLAN management |
Encryption Algorithm | 128-bit WEP, 64-bit WEP, 152-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise |
Authentication Method | Secure Shell (SSH) |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac Wave 2 |
Aerial | |
Antenna | Internal |
Antenna Qty | 4 |
Gain Level | 4 dBi |
Expansion / Connectivity | |
Interfaces | 3 x 1000Base-T (PoE+) - RJ-45 , 1 x 1000Base-T (uplink) - RJ-45 |
Miscellaneous | |
Compliant Standards | FCC, RoHS |
Power | |
Power Consumption Operational | 9.8 Watt |
Software / System Requirements | |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
