The EAP115-Wall would blend seamlessly into any business setting with a refined, minimalist appearance. A slimline design includes casing thats just 11 mm in thickness.
Product Description | TP-Link Omada EAP115-Wall - radio access point - Wi-Fi | Device Type | Radio access point | Form Factor | Wall mountable | Localisation | Europe | Data Link Protocol | Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n | Included Accessories | Mounting screws | OS Required | Microsoft Windows XP, Microsoft Windows Vista / 7 / 8 / 10 | Power Over Ethernet (PoE) Supported | PoE | Dimensions (WxDxH) | 8.68 cm x 8.68 cm x 3.02 cm |
General | |
Width | 8.68 cm |
Depth | 8.68 cm |
Height | 3.02 cm |
Networking | |
Connectivity Technology | Wireless |
Data Transfer Rate | 300 Mbps |
Remote Management Protocol | SNMP 1, Telnet, SNMP 2c, HTTP, HTTPS |
Features | Load balancing, Syslog support, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support, reset button, Watch Dog Timer (WDT), SSID to VLAN mapping |
Encryption Algorithm | 128-bit WEP, 64-bit WEP, 152-bit WEP, WPA, WPA-PSK, WPA2-PSK, WPA2-Enterprise |
Compliant Standards | IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n |
Aerial | |
Antenna | Internal |
Antenna Qty | 2 |
Directivity | Omni-directional |
Gain Level | 1.8 dBi |
Expansion / Connectivity | |
Interfaces | 1 x 100Base-TX (PoE) - RJ-45 |
Miscellaneous | |
Compliant Standards | RoHS |
Power | |
Power Consumption Operational | 2.8 Watt |
Software / System Requirements | |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
