TP LINK PoE kit PoE Kit 1 Injector + 1 Splitter 12/9/5V
£21.26
36 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Delivers power and data through a single Ethernet cable for simple network extension
  • Transmits power and data over an Ethernet cable up to 100m away
  • Plug and Play design provides a hassle free setup
  • 12/9/5VDC triple output adapts to different Ethernet-enable devices
  • Type: Power Injector
  • Stock Status: In Stock
Product codes
The TL-POE200 is designed to deliver power and data over a single Ethernet cable to an Ethernet enabled device up to 100m away. The PoE kit uses two devices, one, the 'injector' injects power and data into a single Ethernet cable while the other, the 'splitter' placed at the receiving end splits the power and data back into two cables to be used by the connected Ethernet device. This convenience allows users to place Ethernet enabled devices such as access points, IP cameras, or VoIP phones anywhere that they are best suited, regardless of whether a power socket is available, to achieve the best performance for the connected devices.
Product Description TP-Link TL-POE200 - repeater - 10Mb LAN, 100Mb LAN
Device Type Repeater
Form Factor External
Data Link Protocol 10Mb LAN, 100Mb LAN
Max Transfer Distance 100 m
Power Over Ethernet (PoE) PoE
Dimensions (WxDxH) 8.1 cm x 5.2 cm x 2.4 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
TP LINK PoE kit PoE Ki...
£21.26
