TP LINK Portable 3G/4G Wireless N Router
£24.22
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Share a 3G mobile connection, compatible with 120+ UMTS/HSPA/EVDO 3G USB modems, tested in the field
  • Travel-size design, small and light enough to take on the road, enables users to share a 3G mobile connection wherever 3G coverage is available
  • Wireless speed is up to 150 Mbps
  • With 3G/WAN failover back-up strategy, TL-MR3020 can provide a sustained Internet connection
  • Type: Wireless router
  • Standards: Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g + 1 more
  • Speed: 300Mbps
  • Stock Status: In Stock
Product codes
What make this router outstanding are its travel-size design and Mini USB Port, which can be connected to a laptop or power adapter to be used as a power supply. As long as you have your laptop, the TL-MR3020 can be powered and a wireless cloud is created that can be shared by iPads, iTouches, Android Phones, Kindles and the vast majority of other portable Wi-Fi enabled devices.
Compatibility is the most important aspect to consider when you're selecting a 3G router. TP-LINK has made certain that 3G routers are compatible with the ISPs in the regions in which they are sold.
With one button security setup, the TL-MR3020 allows users to instantly setup their security simply by pressing the WPS button on the router and automatically establishing a WPA2 secure connection, which is more secure when compared with WEP encryptions. Not only is this faster and safer than normal security setups but more convenient in that users needn't remember a password!
Bandwidth of mobile broadband is limited. With the router's IP QoS function, the TL-MR3020 allows optimum utilization of bandwidth and offers bandwidth control over congestion, preventing bandwidth abuse. When sharing your mobile broadband with others, you can decide how the bandwidth is shared based on your requirements.
The TL-MR3020 can be installed quickly and easily almost anywhere. All you need to do is insert the USB modem into the router, search for its wireless SSID on your computer and connect to it. Users can be online and surfing the Internet in no time, with the user guide on provided CD, even novice users can easily set up their wireless Internet connections.
Product Description TP-Link TL-MR3020 - v3 - wireless router - 802.11b/g/n - desktop
Device Type Wireless router
Enclosure Type Desktop
WAN Ports Qty 1
Data Link Protocol Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band 2.4 GHz
Data Transfer Rate 300 Mbps
Features DoS attack prevention, IPv6 support, parental control, Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS), reset button, bandwidth control, IPv4 support, Stateful Packet Inspection Firewall (SPIF), 3G/4G USB Dongle Support, IP-MAC binding, DMZ support
Compliant Standards UPnP
Dimensions (WxDxH) 7.4 cm x 6.7 cm x 2.2 cm
System Requirements UNIX, Apple MacOS, Novell NetWare, Linux, Windows 8.1 / 10, Microsoft Windows 98SE/2000/NT/XP/Vista/7/8
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK Portable 3G/4G...
£24.22
