Boost Your Router Coverage to Expanded Dual Band WiFi
RE200 expands your existing WiFi coverage with next generation 11AC WiFi technology. It works with any standard WiFi router and creates stronger dual band connections in hard-to-reach areas, allowing you to enjoy seamless wireless coverage throughout your home or office.
Next Generation 11AC WiFi
Create faster access for 802.11 b/g/n and 802.11ac WiFi devices. RE200 delivers fast speeds of dual band WiFi up to 750Mbps and provides reliable connections for laptops, smartphones, tablets and other wireless-enabled devices.
*Actual WiFi speeds may vary due to different user environments.
Enjoy Super Speeds in High Speed Mode
With High-Speed technology, RE200 makes the best use of both WiFi bands to establish super speedy connections -- ideal for HD video streaming, online gaming and other bandwidth-intensive tasks.
*In high speed mode, RE200 offers maximum performance but limits connection to one band (2.4GHz or 5GHz).
Easy Setup and Flexible Placement
Press the WPS button on your router and the Range Extender button on your RE200 within 2 minutes to easily connect to the network. Once connected with an existing router, you can simply unplug and plug the RE200 back in anywhere within the wireless range of the existing router, without needing to configure the extender again.
*The band used when connecting via the WPS buttons is sometimes indefinite and dependant on the settings on your router. If you want to establish a WPS connection in both 2.4GHz and 5GHz bands, please go to the RE200's web configuration page to configure this.
Entertainment Adapter
The RE200's single Ethernet port allows the Extender to function as a wireless adapter to connect wired devices like Blu-ray® players, gaming consoles, DVRs and Internet TVs. At the same time, the device can share the wireless network as well.
Product Description | TP-Link RE200 - Wi-Fi range extender | Device Type | Wi-Fi range extender | Form Factor | External | Data Link Protocol | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz, 5 GHz | OS Required | UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows Vista / XP / 7 / 8 | Dimensions (WxDxH) | 11 cm x 6.58 cm x 7.52 cm |
General | |
Width | 11 cm |
Depth | 6.58 cm |
Height | 7.52 cm |
Networking | |
Connectivity Technology | Wireless |
Data Transfer Rate | 750 Mbps |
Line Coding Format | DBPSK, DQPSK, CCK, 64 QAM, 16 QAM, OFDM |
Spread Spectrum Method | OFDM, DSSS |
Network / Transport Protocol | TCP/IP, DHCP |
Features | DHCP support, MAC address filtering, wall mountable, Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS), wireless bridge mode, reset button |
Encryption Algorithm | 128-bit WEP, 64-bit WEP, 152-bit WEP, WPA-PSK, WPA2-PSK |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, IEEE 802.11ac |
Aerial | |
Antenna | Internal |
Antenna Qty | 3 |
Expansion / Connectivity | |
Interfaces | 1 x 100Base-TX - RJ-45 |
Miscellaneous | |
Cables Included | 1 x network cable |
Compliant Standards | FCC, RoHS |
Power | |
Power Device | Internal power supply |
Power Consumption Operational | 6.5 Watt |
Software / System Requirements | |
Software Included | Drivers & Utilities |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
