We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Tired of Wi-Fi dead zones in your home The RE205 Range Extender connects to your Wi-Fi router wirelessly, strengthening and expanding its signal into areas it can't reach on its own, while reducing signal interference to ensure reliable Wi-Fi coverage throughout your home or office.
The RE205 lets you keep more devices connected at the same time with its 2.4GHz 300Mbps and 5GHz 433Mbps dual bands. Use the 2.4GHz band to send email and browse the web, and the 5GHz band for gaming and HD streaming.
Product Description | TP-Link RE205 - Wi-Fi range extender - Wi-Fi 5 | Device Type | Wi-Fi range extender | Form Factor | External | Data Link Protocol | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz, 5 GHz | OS Required | UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 | Dimensions (WxDxH) | 7.8 cm x 8 cm x 7.7 cm | Manufacturer Warranty | 2-year warranty |
General | |
Width | 7.8 cm |
Depth | 8 cm |
Height | 7.7 cm |
Networking | |
Connectivity Technology | Wireless |
Data Transfer Rate | 750 Mbps |
Remote Management Protocol | HTTP |
Wi-Fi Rating | AC750 |
Status Indicators | Signal strength |
Features | Manageable, Access Point operational mode, firmware upgradable, Wi-Fi Protected Setup (WPS), reset button, wireless extender mode, WPA encryption, wireless SSID |
Encryption Algorithm | 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac |
Aerial | |
Antenna | External integrated |
Antenna Qty | 2 |
Expansion / Connectivity | |
Interfaces | 1 x 100Base-TX - RJ-45 |
Miscellaneous | |
Cables Included | 1 x network cable |
Compliant Standards | FCC, RoHS |
Power | |
Power Device | Internal power supply |
Power Consumption Operational | 7.3 Watt |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
