Boost Your Wi-Fi to hard-to-reach Areas
Place the RE220 between your wireless router and wireless devices, expanding Wi-Fi coverage while eliminating Wi-Fi dead zones. The dual-band Wi-Fi up to 750 Mbps can not only extend to 32,00 sq. ft. (300m2) with the router, but also make good use of your high ISP speed , ideal for HD video streaming, online gaming and other bandwidth-intensive tasks.
Stable Dual Band Connection for More Devices
The RE220’s Wireless AC technology creates faster and stronger Wi-Fi connections across your home and extends dual band Wi-Fi up to 750 Mbps. Dual 2.4 GHz and 5 GHz bands provide Wi-Fi connections to up to 32 devices, allowing you to enjoy stable and drop-free experience on all your devices.
Product Description | TP-Link RE220 - Wi-Fi range extender - Wi-Fi 5 | Device Type | Wi-Fi range extender | Form Factor | External | Data Link Protocol | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz, 5 GHz | Performance | Maximum data rate (2.4 GHz): 300 Mbps , Maximum data rate (5 GHz): 433 Mbps | OS Required | UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows XP / Vista / 7 / 8 / 10 | Dimensions (WxDxH) | 7.52 cm x 6.58 cm x 11 cm |
General | |
Width | 7.52 cm |
Depth | 6.58 cm |
Height | 11 cm |
Networking | |
Connectivity Technology | Wireless |
Data Transfer Rate | 750 Mbps |
Wi-Fi Rating | AC750 |
Status Indicators | Power, 5 GHz, 2.4 GHz, Wi-Fi |
Features | Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS), reset button |
Encryption Algorithm | 128-bit WEP, 64-bit WEP, 152-bit WEP, WPA-PSK, WPA2-PSK |
Compliant Standards | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac |
Aerial | |
Antenna | Internal |
Antenna Qty | 3 |
Expansion / Connectivity | |
Interfaces | 1 x 100Base-TX - RJ-45 |
Miscellaneous | |
Compliant Standards | FCC, RoHS |
Power | |
Power Device | Internal power supply |
Power Consumption Operational | 6.5 Watt |
Software / System Requirements | |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
