RE300 wirelessly connects to your Wi-Fi router, strengthening and expanding its signal into areas it can't reach on its own.
Product Description | TP-Link RE300 - Wi-Fi range extender - Wi-Fi 5 | Device Type | Wi-Fi range extender | Form Factor | External | Data Link Protocol | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz, 5 GHz | OS Required | UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows XP / Vista / 7 / 8 / 10 | Dimensions (WxDxH) | 6.9 cm x 5.2 cm x 12.4 cm |
General | |
Built-in Devices | Led panel |
Width | 6.9 cm |
Depth | 5.2 cm |
Height | 12.4 cm |
Networking | |
Connectivity Technology | Wireless |
Remote Management Protocol | HTTP |
Status Indicators | Signal strength |
Features | Manageable, firmware upgradable, Wi-Fi Protected Setup (WPS), reset button, Smart Roaming, Wireless Mesh support |
Encryption Algorithm | 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, IEEE 802.11ac |
Aerial | |
Antenna | External integrated |
Antenna Qty | 2 |
Miscellaneous | |
Compliant Standards | FCC, RoHS |
Power | |
Power Device | Internal power supply |
Power Consumption Operational | 7.3 Watt |
Software / System Requirements | |
Dimensions & Weight (Shipping) | |
Shipping Width | 10.15 cm |
Shipping Depth | 8.9 cm |
Shipping Height | 15.6 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
